Discarding used hydraulic/transmission fluid?
   / Discarding used hydraulic/transmission fluid? #31
i prefer to take it oil recycling so that it goes back into the oil food chain. Just my :2cents:
   / Discarding used hydraulic/transmission fluid? #32
It came from the Ground, why not put it back there?
BTW - I did do that, 40 years ago...
   / Discarding used hydraulic/transmission fluid? #33
I hear that, and that's always a good option.
But for the sake of arguments, when it's dumped in with used dirty engine oil, it simply looks like used, dirty engine oil.
Nobody would have a cause to ask what it is.
   / Discarding used hydraulic/transmission fluid? #34
The one in Clallam County (Port Angeles) also takes used oil filters.
I usually build-up a certain amount of them in a box, then take them there.
-No more mess in the garbage.
   / Discarding used hydraulic/transmission fluid? #35
can it just be filtered and reused? seems like a tremendous waste to me. Although I've been known to keep a few gallons and use it for cutting oil on the drill press and in the oil can for various uses.
   / Discarding used hydraulic/transmission fluid? #36
I just did a horrible (and highly elusive) hydraulic repair job. Man, a lot of oil got away on me. At $100.00 / pail! Sometimes the harder you try to be responsible, the worse it gets! Finally, you just say F$%$% it!
   / Discarding used hydraulic/transmission fluid? #37
   / Discarding used hydraulic/transmission fluid? #38
Giyi Tree Sheer (A57149)
Giyi Tree Sheer...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2019 WANCO  LIGHT PLANT (A58216)
2019 WANCO LIGHT...
48 Inch Farm Jack (A57454)
48 Inch Farm Jack...
CAT930K (A58216)
CAT930K (A58216)
