disc plow
/ disc plow #11
hillers are a bit of a different animal.
enough weight will be needed to make use of traction too.
a 40 hp tractor that is light and can't get traction may plow worse than a perfectly ballasted 30hp machine.
Yep. That was my point. I've plowed many, many acres with an 8N and 2 bottom moldboard plow. Can't remember their HP, 24 maybe??
/ disc plow #12
8n, 27 pto depending on who you quote. 23 for the 2n/9n if using 2n/9n head..
/ disc plow #13
hillers are a bit of a different animal. enough weight will be needed to make use of traction too. a 40 hp tractor that is light and can't get traction may plow worse than a perfectly ballasted 30hp machine.
I agree. I assume the OP is talking about a disc plow as pictures in one of the earlier posts show that have 30+inch diameter discs. Totally diff than hilling disc attachments. They require considerably less HP/weight than a moldboard plow.
Terry
/ disc plow #14
We used to pull 2 16" turn plows with our old Jubilee all day long 20.2 HP but tractor data says 26.8 at the drawbar which I find hard to believe.
/ disc plow #15
Dad pulled a set of Ferguson 3pth 2 bottom disk plows, 26'' disks, with a nearly new gas 3000 ford, 14.9 x 28 ballasted rears. He pulled it in 2 or 3 gear and the Ford "didn't want no more". Plowing 8-10 inches in mostly Baxter clay soils. The plows were very heavy and made the tractor light in the front. In my experience disk plows leave a field very rough and hard to disk.
/ disc plow #16
a jube with the 134 red tiger has about 33 hp belt anyway.. 2 16's is quite a load..... pre worked earth or sand?
/ disc plow #17
Used a borrowed 2 disk plow to do my field with my L2850. Needed 4 wheel drive. No problems. However, I agree with the rough field. Had to put the seat belt on to run the disk.
/ disc plow #18
You're moving the same amount of dirt in a disc hiller with discs opposed as you are with the discs parallel to each other. So, a given hp/drive (2wd heavier tractor or 4wd lighter tractor) will pull it.
Problem with a lighter tractor is that the side force generated by the parallel discs could throw the tractor into not going straight. That's why I said that a disc plow with a good trail wheel may work on a light tractor.
This is what my little Gravely tractor had with a single rotating plow, a trail wheel of sorts that kept the tractor going straight.
It wasn't a "trail wheel" on the Gravely, but a leading set of wheels. With at least one wheel up against the ridge made by the previous plow run, the machine would go straight.
Ralph
/ disc plow #19
Both, pre-worked for years and also fresh cut in fields not touched in years. Some of the soil was sandyish!
/ disc plow #20
pre-worked and sandy are a bit easier to turn. lets you get away with less engine to plow ratio...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
2018 HINO SA (A58214)
2017 Jeep Patriot 4x4 SUV (A59231)
2017 Jeep Patriot...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A59228)
2006 GEA Westfalia...
2023 GMC Seirra Elevation Crew Cab 4X4 Pick-up Truck (A60352)
2023 GMC Seirra...
2017 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A59230)
2017 GMC Sierra...
