disc plow
/ disc plow #11
hillers are a bit of a different animal.
enough weight will be needed to make use of traction too.
a 40 hp tractor that is light and can't get traction may plow worse than a perfectly ballasted 30hp machine.
Yep. That was my point. I've plowed many, many acres with an 8N and 2 bottom moldboard plow. Can't remember their HP, 24 maybe??
/ disc plow #12
8n, 27 pto depending on who you quote. 23 for the 2n/9n if using 2n/9n head..
/ disc plow #13
hillers are a bit of a different animal. enough weight will be needed to make use of traction too. a 40 hp tractor that is light and can't get traction may plow worse than a perfectly ballasted 30hp machine.
I agree. I assume the OP is talking about a disc plow as pictures in one of the earlier posts show that have 30+inch diameter discs. Totally diff than hilling disc attachments. They require considerably less HP/weight than a moldboard plow.
Terry
/ disc plow #14
We used to pull 2 16" turn plows with our old Jubilee all day long 20.2 HP but tractor data says 26.8 at the drawbar which I find hard to believe.
/ disc plow #15
Dad pulled a set of Ferguson 3pth 2 bottom disk plows, 26'' disks, with a nearly new gas 3000 ford, 14.9 x 28 ballasted rears. He pulled it in 2 or 3 gear and the Ford "didn't want no more". Plowing 8-10 inches in mostly Baxter clay soils. The plows were very heavy and made the tractor light in the front. In my experience disk plows leave a field very rough and hard to disk.
/ disc plow #16
a jube with the 134 red tiger has about 33 hp belt anyway.. 2 16's is quite a load..... pre worked earth or sand?
/ disc plow #17
Used a borrowed 2 disk plow to do my field with my L2850. Needed 4 wheel drive. No problems. However, I agree with the rough field. Had to put the seat belt on to run the disk.
/ disc plow #18
You're moving the same amount of dirt in a disc hiller with discs opposed as you are with the discs parallel to each other. So, a given hp/drive (2wd heavier tractor or 4wd lighter tractor) will pull it.
Problem with a lighter tractor is that the side force generated by the parallel discs could throw the tractor into not going straight. That's why I said that a disc plow with a good trail wheel may work on a light tractor.
This is what my little Gravely tractor had with a single rotating plow, a trail wheel of sorts that kept the tractor going straight.
It wasn't a "trail wheel" on the Gravely, but a leading set of wheels. With at least one wheel up against the ridge made by the previous plow run, the machine would go straight.
Ralph
/ disc plow #19
Both, pre-worked for years and also fresh cut in fields not touched in years. Some of the soil was sandyish!
/ disc plow #20
pre-worked and sandy are a bit easier to turn. lets you get away with less engine to plow ratio...
1042 (A60430)
1042 (A60430)
THREE POINT ATTACHMENT (A58214)
THREE POINT...
2021 Bobcat T66 (A60462)
2021 Bobcat T66...
1997 10ft. Crosley S/A Utility Trailer (A59231)
1997 10ft. Crosley...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
Richardton 960 (A60462)
Richardton 960...
