Disc Harrow Alterations
/ Disc Harrow Alterations
jenkinsph said:
deere5105,
Have you considered the possibility of shaving the outside spacer spool just enough to get an extra thread or two? If you can do this it should help with getting the square shoulder more room to lock on too. I am referring to the spacer between the last two blades on this gang.
Have not considered that. I guess another option similar to that would be to purchase a different width spacer that was sized for 7.5" spacing versus the 9" spacing I have now. Might accomplish the same thing and be easy to swap back if needed.
/ Disc Harrow Alterations #102
Might wan't to buy another 9" spacer and use a chop saw to cut out a small slice in the middle and stick back together. Leave enough to have clean threads to tighten against.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 CAT 928H WHEEL LOADER (A60736)
2008 CAT 928H...
2022 BIG TEX 22GN-35BK+5MR T/A 48FT GOOSNECK TRAILER (A59906)
2022 BIG TEX...
2023 Global Trailers GT302 30ft. 60YD T/A End Dump Trailer (A61568)
2023 Global...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2016 Dodge Grand Caravan van (A61569)
2016 Dodge Grand...
