Rotary Cutter disassembly
/ disassembly #1
jwp20613
masseyferguson 245 diesel
What is the best way to get the stuck stump protector off a 20-year old ,240 series mf/pittsburgh rotary cutter to replace a leaking seal? Thanks.
/ disassembly #3
/ disassembly
Thanks much! I'll get two of my 250lb neighbors, put crowbars in their hands and turn 'em loose.
/ disassembly #5
If the stump jumper is also the drive disk for the blades, I would take off the big center nut and go cut some brush in a field for a while until you hear the disk get loose and fall off the shaft. The tapered spline usually isn't stuck all that hard - just hard to get off with hand tools. The disk and blades won't get hurt falling to the ground. They'll be spinning but will quickly stop. You'll be up above it on the tractor seat out of harm's way.
/ disassembly
Thanks. If my 250 lb neighbors with prybars doesn't work, I'll give it a shot.
(4) Wheels and Tires (A65640)
(4) Wheels and...
(16) Kinze Brush Meters (A65640)
(16) Kinze Brush...
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Suzuki King Quad 700 (A62613)
Suzuki King Quad...
2011 Chevrolet Silverado 1500 Work Truck (A62613)
2011 Chevrolet...
New/Unused 3 Point Receiver Hitch Attachment (A65583)
New/Unused 3 Point...
