Dirt scoop?
/ Dirt scoop? #11
The reason I changed my lower lift arms, is because someone had cut and rewelded them shorter some time in the past. The ends did not even make it out to the edges of the tires.
As for size, as long as you have the cat1 pins mounted on the the tractor, everything should just pin right up. Mine changed over in about 2 minutes. I used a pair of needle nose pliers to remove/instal the cotter pins for the link arms from the the upper lift arms to the lower lift arms.
The ones from TSC are for the ford 8N, and are about 3' long, give or take... ( may actually be closer to 33" ) They are about 35 bucks a piece, and are bright -burn your eyes- red.
I love mine... perfect size on the 1700.... gives you good tire clearance.. even on the big cleat tires.
One think though... make some chain limiters to hook up everything and keep it from swinging. On my 1700, there were looks under the axles for this. A chain from there to the end of the link pin at impliment hookup, and anohter on the other side, if using a pto device. If no pto, I use an x pattern, chain from the right axle loop to the the union of the link arm and the left lower lift arm, and etc on the left axle loop to the union of the link arm and right lower lift arm.
Keeps the arms out of the tires.... and you want to do that, becaus ethe tractor is way strong enough to bend your link arms... I bent one of mine on my first day with my box blade.
Then I got the limiter chains...
Soundguy
/ Dirt scoop? #12
I've had pretty good luck so far with my dirt scoop (Kingcutter 30") on my 4300.
There are two problems, if you can call them that.
1) There is no down-pressure on the 3pt hitch, so sometimes I want to dig and the scoop just floats over the ground. Then it's time to get off, adjust the top link, try again, etc.
2) It doesn't lift very high. Trying to load a pickup with dirt, I could just barely clear the tailgate, which meant I couldn't dump. So back up to the truck, then shovel the dirt from the scoop into the truck.
It isn't a FEL, but it's a lot cheaper.. and for most jobs I've run into it's "close enough for gummint work." /w3tcompact/icons/smile.gif
Bob
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A61307)
2021 Gehl RT215...
2013 FORD F250 (A60460)
2013 FORD F250...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
Topsoil Trommel (A57453)
Topsoil Trommel...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
