Dirt scoop uses
/ Dirt scoop uses #1
specialkkl
PA
2006 mahindra 2615 hst
Just trying to figure out other uses for a dirt scoop. I was thinking of picking one up for some ballast on the back. Other than that it seems kind of awkward for any other use. Is it worth it?
/ Dirt scoop uses #2
I could have picked one up from the guy I bought my disc from for probably less than $100. Since I don't have a FEL I could use it to move around a small amount of dirt. But I think they are only $200 new at TSC.
If you have a FEL I don't see much use.
/ Dirt scoop uses #3
If you don't have a FEL, they are great to have. I use mine to carry dirt from the backyard to areas that need a little leveling, or potholes in the driveway.
They are better than a wheelbarrow for hauling off broken brick and concrete, which was the last time I used mine. I was asked to remove the brick sign in front of the Church up the street, and I used it to haul off the broken up pieces over to where we were disposing of it.
I have considered building a larger one, since my 24" one is a little small for the 70 hp tractor. Just haven't gotten around to it.
David from jax
/ Dirt scoop uses #4
I've got one that I picked up for $45 at an auction. I've used it to clean out a drainage swale, but other than that, I haven't found much use for it.
/ Dirt scoop uses #5
I also picked one up cheap and I use is really just as an extra place to carry stuff. I have been moving a lot of medium sized stones on my property. I hand fill the loader and then fill the rear bucket as well. Just gives me double the capacity for stuff like that in a single run.
/ Dirt scoop uses #6
I bought a used Ford scoop for $75. It's a great attachment to have. I don't have a loader so I use my scoop to haul dirt frequently. Most recently cut a sloped bank and created a flat slab along my shop for an addition. This required simple excavation and carrying the dirt away. Worked sweet. Even if you have a loader and are trying to move a large quantity of dirt very far it would increase your carrying ability by 60-70% depending on how big your bucket is.
I grew up using an old Ford scoop on various Ford tractors. Very handy attachment that is cheap to own. If you can find a used one for $100 or less versus buying a new one for $200, buy the used one. I've never saw a dirt scoop that was worn out!!!! My old Ford scoop is reversable and definitely more durable than the new ones offered at TSC.
/ Dirt scoop uses #7
for me, my Dirt scoop has been used for:
Extra load carrying when loader id full.
ballast for rear
cutting 30 inch paths
supporting gravel road smoothing and leveling
limited loader work until you get a loader
precision dirt removal in placed you can't use your loader
patio foundation dirt removal
carrying furutre college students from parked location to job site - standing room only:)
/ Dirt scoop uses #8
My grandfather dug our half acre pond with his and an 8N Ford. Worked great, I guess. I was just a baby. Worked great, that is until they put it on the 2N and my uncle got confused (different shift pattern) and backed it into the water.
All rescued and I still have both tractors and the scoop.
/ Dirt scoop uses #9
Glad all were safe, especially your uncle.
/ Dirt scoop uses #10
If I had a tractor with no FEL and could only buy one implement, I'd buy a boxblade. If I could buy two, I'd be torn between a post-hole digger and a dirtscoop as the second choice. Ah, what the heck...buy all three and put a smile on your face.:D
2008 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2008 Dodge Ram...
2022 EZ-GO ELITE...
Landhonor Plasma Cutter (A66408)
Landhonor Plasma...
43018CFL (A59228)
43018CFL (A59228)
3268 (A63117)
3268 (A63117)
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
