Dirt Scoop Differences
/ Dirt Scoop Differences #2
About the biggest differences i see are 1), it is not reversable.. That unit looks like it is only designed to be towed . many of the modern dirt scoops are reversible, so you can use as a self loading 'pan' while driving, or you can face them backwards and back into a pile.. this is accomplished by a double top frame and 2 sets of pins... and 2), the front lip doesn't appear to have a reinforced cutting edge like my KK unit has.. etc.
otherwise.. if you are using it as a pull to load setup.. it should function nearly the same. Dump/release is by a slightly different scheme than the trip lever dump that KK used.. etc... but that does not effect function that much.
( I prefer backing into piles.. so i like the reversable ones.. etc. ).. however from a collectors point of view.. I might get it to go with my older tractor.. etc..
soundguy
/ Dirt Scoop Differences #3
WAY overpriced in my opinion.
Used to see those all the time on fleabay for $50.
I have a scoop made by J Bar equipment.
I got it off fleabay for $66. One of my most used implements.
It is reversable. Very handy to use backwards sometimes.
I did make one modification to it so that it was easier to dump.
One of these days I will have to get pictures of what I did
cause there is no way I could explain it.
I do wish it was bigger. It is 24w x 24L x 12d.
But if it was bigger it mite be too much for the tractor.
Otherwise I love my dirt scoop.
Pooh Bear
/ Dirt Scoop Differences #4
A 30" wide scoop is pretty common, so keep your eye's open. I built a bucket to mount on the boom mower to load some dirt with, and left open the possibility of making a scoop out of it, when the flair mower goes back on. It is 42" wide, so should make a great scoop for my JD.
David from jax
Thanks. I need to be able to reverse the scoop. I figured there was something different about it.
/ Dirt Scoop Differences #6
Finally an issue I can really comment on since I am a new guy and a real novice. I recently bought an import dirt scoop that looked heavy enough to do a little light digging in a dry stream bed. It lasted all of about 2 hours before bending and becoming useless. Yesterday, I bought a 30" reversable dirt scoop by King Kutter and it is a winner for sure. That one on ebay will be good for picking up a tiny bit of dirt and no digging at all. I would not bother with such a light weight item and it is WAY overpriced.
How are the scoops from TSC? Are they cheap imports or decent quality? How much should a heavy duty scoop cost from a local dealer?
/ Dirt Scoop Differences #8
I paid $320 for a KK 30" made out of 3/8" steel. Weighs about 100 pounds more than the import model I bent.
2007 Rhodes AS3573 Trailer, VIN # 1A9AD35307P432073 (A64556)
2007 Rhodes AS3573...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64553)
2017 Caterpillar...
84 Inch Grapple Bucket (A64553)
84 Inch Grapple...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2015 CATERPILLAR 336FL EXCAVATOR (A65053)
2015 CATERPILLAR...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
