Digging with FEL?
/ Digging with FEL? #1
arrowem
Hi,
I will be getting a new 4x4 with fel but now have 8n with fel and am wondering about the capabilities of the new stuff. My question is: I am clearing a new yard area (about 1.5 ac) and most of it is pretty clean but there are a few Tag Alder tree stumps (anyone know what those are.....%$&*%$ blasted weed trees) anywhere from 3" to 10". These are not regular stumps like oak or maple..etc... the're more like a big brush tree. I was going to rent a dozer to get them out (maybe a dozen sporadicly placed) and then use the new tractor to plow,disk,level, seed, pack, and pray for rain. BUT!!! if I could use the FEL to get the buggers out then I would not have to rent the dozer, hence saving money and use that as a selling point for getting the 4x4 with FEL(ordered but haven't broken it to The Queen yet :0
Thanks,
Jason
/ Digging with FEL? #2
You can dig with the standard FEL bucket, but if you really want to dig get a tooth bar (about $300) for the edge of the bucket. Do a search on 'tooth bar' and you will see a whole lot of posts.
/ Digging with FEL? #3
I too have an 8N with a FEL, it has the narrow bucket and no down pressure. However I did a lot of digging with it. Now to round out the fleet I have a Kubota L3000DT with FEL.
There is a tremendous difference it the ability of this machine to dig over the 8N simply because of the ability to curl the bucket and apply some downward pressure.
I do not have a toothbar, yet, I can see how much of a difference one would make when it comes to loosening up hard ground and small roots.
What size tractor are you looking to purchase? I tried to purchase something equal to the 8N when I was looking at tractrors. There is nothing in the compact line that matches the width of the N-series or the stability on a side hill. Horsepower and weight can be close or more than the 8N.
I really like my Kubota it goes places I only dreamed of before, and I can do much more with it than I could with my 8N. But there is a big difference in feel from one to the other. You will love 4WD.
Randy
/ Digging with FEL? #4
<font color=blue>"These are not regular stumps like oak or maple..etc... the're more like a big brush tree.</font color=blue>
Jason,
There's a great thread in the Projects section titled "Unbelievable" that shows how to remove stumps with forks. A lot of good pics too!
/ Digging with FEL? #5
I took care of a 7" diameter sumac with my TC35. I used the tooth bar to undermine and break some roots. Then I raised the bucket about 7' in the air and starting pushing. The tree went over no problem. My wife was convinced that we would need to get a dozer to push it down but I proved her wrong.
Can't hurt to try your new baby... what did you get?
Peter
/ Digging with FEL? #6
<font color=blue>"Can't hurt to try your new baby... what did you get?"</font color=blue>
Peter,
I didn't get anything yet /w3tcompact/icons/sad.gif! I think you want to ask Arrowmen (Jason) that question. He was the one that started this thread. /w3tcompact/icons/smile.gif
/ Digging with FEL? #7
My TC45 with FEL does a WHOLE lot more than my 8N with FEL ever could. I have a toothbar that really helps with the digging and I take out cedar stumps every time I'm in the seat.
mike
/ Digging with FEL?
I ordered a JM345-35hp with fel.
/ Digging with FEL? #9
I would further add get the heavy duty toothbar with the bigger, thicker shanks. These will do some damage to these stumps provided they're not deep rooted.
/ Digging with FEL? #10
I've only got a lowly B7500, but I've removed many "brushy" kinds of stuff (bacharus if you know western plants) with the FEL. Once it gets above a certain size, I wrap a chain around it, tie the chain to the boxblade, then lift & separate it from the ground. I then drag it off for a different kind of ceremony.
/ Digging with FEL? #11
RE-Toothbars-the dealer I picked up my used YM336d (33 engine hp Yanmar, 4wd, FEL (2800 breakout, 1500lbs maximum lift)) recommended against putting a tooth bar on, and said they were only for "bigger tractors"-is this the case, or simply an old "wives tale"?
Thank you in advance,
Couchsachraga
/ Digging with FEL? #12
Old wives tale. I have a 36 hp tractor, with similar specs on the FEL. It is amazing the differance the toothbar makes when digging in grass covered or hard packed earth.
/ Digging with FEL? #13
POPPYCOCK: i have a b2400(24hp) and the toothbar really helps for loosening hard dirt, digging and moving brush only thing is have to be careful if u snag a deep root and u are to hard on the joystick, will raise u off groung real quick/w3tcompact/icons/eyes.gif
/ Digging with FEL? #14
Thank you! Now, to fashion or buy a toothbar and REALLY start having fun /w3tcompact/icons/smile.gif.
Couchsachraga
/ Digging with FEL? #16
<font color=blue>I am clearing a new yard area (about 1.5 ac) and most of it is pretty clean but there are a few Tag Alder tree stumps (anyone know what those are.....%$&*%$ blasted weed trees) anywhere from 3" to 10". </font color=blue>
I think they are related to the birch.
Don't cut them! They have very shallow roots and tend to grow along the wetland. I simply push them over and then hook some part of the roots with the FEL
and out they come. They are no good for firewood and rot down pretty fast.
2005 Rolls Rite 26ft. 24 Ton T/A Tag Tailer (A61573)
2005 Rolls Rite...
6R BEDDER (A63291)
6R BEDDER (A63291)
ROANOKE G195 BRUSH-AX LONG ARM MOWER (A63291)
ROANOKE G195...
2020 International LT625 48" Sleeper (A62613)
2020 International...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
