Dig-It towable Backhoe partial restoration
/ Dig-It towable Backhoe partial restoration #81
Hey Guys, I'am pleased to see a discussion on the Digit 148, I have a 148 and rebuilding to working condition, I do not have any owners Manuel or any info, Trying to set the bearings in the front drive wheels, And can't get any movement in the Notched Collar I have loosened the Retaining washer, Does the Wheel mount Back Plate simply move back and collar snugs to it or is the Back plate threaded as well, Thanks for any help
my manual only shows a splined connection for the main hub. Two sets of snap rings backed by seals is what it shows holds the main hub to the motor in the assembly. Is it possible the splined connector is rusted and stuck? I have not taken my hub apart yet so I dont have any experience with that.
/ Dig-It towable Backhoe partial restoration #83
The Hub where The tire is mounted, The t lever for locking and unlocking wheels, slides in and out that housing is threaded, there is a collar ring screws on the threaded housing, Looks like it Holding the hub where the tire mounts ,Does the tire Hub screw on that housing like the collar or is it independent
/ Dig-It towable Backhoe partial restoration #84
Where did you get your parts?, in need of pins and bushings as well
call the guys at mission manufacturing. They are the best and cheapest place to get dig it parts.. All other suppliers either make their own parts or buy from these guys.
website is of some help but a manual full of part numbers and a phone call are the best way to get service
powerkingtractor dot com
/ Dig-It towable Backhoe partial restoration #86
Found the control Linkage On my 148 Kolher CH 18 S engine was not operating properly, Missing 2 springs,that I found on a drawing, ordered those, Some one had polish engineered this at some point, The spring they had on it was actually stopping the one stage from returning, Please if anyone has a properly operating Linkage set up, send me some pictures so I can get mine right, THANKS!! 601blues@gmail.com
601 Blues sorry for the late response I have been stupid busy.. I am not sure if they are the same because I have the older Kolher 18 Magnum but next time I am at the property I will take a picture of my linkages and attach them here
/ Dig-It towable Backhoe partial restoration #88
Hey, I just bought whats left of a digit 148, its complete except for the 3 cylinders on the boom, can you guys tell me what size cylinders I need to be looking for?
Mike
Hey Mike welcome to the Dig-It club.. I will try and remember to look at my manual tonight and get you specs.. If they aren't in there, I will get them this weekend when I head up to the property where mine is located. If I have to go to the property it will be late Sunday evening before I can get you the specs.. I have no internet capabilities up there and no cell towers available ;)
Again welcome to the club, once you get it up and running again you will have a blast trying to find ways to use this little but very useful tool
601 Blues I completely forgot I owe you some pics man.. I will get them this weekend and get them posted here. My apologies... Getting way to old and forgetful these days.
/ Dig-It towable Backhoe partial restoration #91
Thanks, no rush I'm pulling the pump off the engine and working on getting it in good running order right now, Mines been sitting 5 years or better, so there is quite a bit of work to do.
Thanks,
Mike
601Blues - sorry not a single spring on any of my throttle controls.. They are all hand controls with solid links. Now mine may be polish engineered as you said also but it seems to work great.
Alabama mike - good news is they are relatively the same with the exception of the boom cylinder, here are the dimensions on mine
Main Boom cylinder
22" closed length pin center to pin center
1.25" attachment pin diameter
1.5" rod diameter
didn't have a hole or cliff nearby to measure max stroke
Dipper arm:
22" closed pin center to pin center
1.25" rod diameter
13" stroke
Curl cylinder
22" Closed length pin center to pin center
1.25" rod diameter
forgot to get stroke measurement
All cylinders have hydraulic connections on the same side of the cylinder. Important if you have the stock hoses for reference
/ Dig-It towable Backhoe partial restoration #93
In all probability all cylinders are the same spec (have the same stroke) for best volume pricing on purchase.
I would not hesitate to order all the same.
In fact even the swing cylinder was same as all boom cylinders.
(I had a Toe Hoe 'Cricket') and that was the case. On that brand they did use an inner sleeve to limit the lift height of that cylinder, made it difficult to load a truck bed or trailer.
/ Dig-It towable Backhoe partial restoration #94
Main Boom cylinder
1.5" rod diameter
Dipper arm:
1.25" rod diameter
13" stroke
Curl cylinder
1.25" rod diameter
Thank you so much, now to start looking for cylinders, LOL
I am betting they can be bought from the guys at powerking tractor for about as good a price as anywhere
/ Dig-It towable Backhoe partial restoration #96
Silly forum makes you have 5 posts before making a post with attachments... here's 1.
/ Dig-It towable Backhoe partial restoration #97
I stumbled upon this thread after my brother and I purchased our Dig It in much need of a restoration. We were needing an excavator on the farm for a few projects and decided instead of paying someone else or rushing the job with a rental we would buy our own, fix it up and sell when we're done with it. That being said I don't think we fully grasped what we were getting into when we bought this Dig It 148. Come to find out it's actually a model 116 per the Name plate but has most of the 148 parts, it must have been when they were transitioning. We're repowering it with a 15hp electric start Lifan motor with an 18amp charging circuit so we can run lights if needed. New wheels and tires all around, new seat, new fenders, new hydraulic drive motor, some new hoses, two new cylinders, new bushings and pins throughout and new decals and paint to freshen it up. Right now we're currently putting it back together and hope to have a complete unit in less than a week.
/ Dig-It towable Backhoe partial restoration #98
Huge thanks to the guys who have shared Mission Manufacturing/Power King tractors. We have spent a load of money with them and they've been very helpful. The manual is a huge help as ours had been improvised on in the past.
/ Dig-It towable Backhoe partial restoration #99
Question I have and I'm sure it varies state to state, do you need to have this thing plated to tow around? Obviously it had lights on it but we didn't see any place for a licence plate.
/ Dig-It towable Backhoe partial restoration #100
The night we picked it up.
Model 116, serial number indicates it's from 1987.
Tearing it down, we were able to rig it up to run on my brothers 13hp Honda GX390 to diagnose which cylinders needed replaced.
Took all the parts to my brothers down the road to pressure wash.
Stripped it down to bare metal
Everything received a couple fresh coats of paint.
New Decals, ours came with the 148 model so we figured to stick with that, given the 116 model came with a different hoe arm.
More pictures to follow once we have it all together. We ran into quite a few problems with this so if anyone has questions feel free to ask, I will subscribe to this thread so I will get any new posts sent to my email.
Thanks for looking,
Jesse
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
213091 (A64276)
213091 (A64276)
2009 Kubota M108S (A60462)
2009 Kubota M108S...
Approximately 100 Ratchet Tie Downs (A65579)
Approximately 100...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2011 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2011 FOREST RIVER...
