Diffs between BX1830 and B7410
/ Diffs between BX1830 and B7410 #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I've found that the both the BX1830 and B7410 have 18 hp diesel engines. What are some of the other differences between these? Think one might be the ability to go into a regular-sized garage door with one vs. the other. Can measure that. Or will the folding ROPS easily fold?
Ralph
/ Diffs between BX1830 and B7410 #2
Ralph, I think you will find the major difference is the physical size of the tractors. The B is a compact, with the BX being a sub-compact. The 7410 does not have power steering (I think), while the BX does.
If you looking to mow lawn, with a few other chores, the BX is the tractor for you. The B7410 is designed to be an economy tractor for those who need a tractor for lots of 3pt hitch work, and need off-lawn capabilities.
Will
/ Diffs between BX1830 and B7410 #3
I think the BX would be better for you. As noted before the B-7410 doen't offer power steering.
/ Diffs between BX1830 and B7410 #4
Ralph,
The B7410 does not have a midmount pto. You wouldn't be able to use a mmm, or a front mount snowblower. The 18hp diesel engine is the same used in the Kubota 2 wheel drive garden tractors. This is what my local Kubota dealer told me. And, as the other post said, no power steering.
arthurb
/ Diffs between BX1830 and B7410 #5
maybe take a look at the 7610? it is pretty much the same size as the 7410..but with more of the bells and whistles (like the bx1830 would have)
John
2016 HAMM HDT90IVV DOUBLE DRUM ROLLER (A64279)
2016 HAMM HDT90IVV...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
Auger Drill Bit Skid Steer Attachment (A61572)
Auger Drill Bit...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
