Different Pole Barn system?
/ Different Pole Barn system? #21
How about an update?
/ Different Pole Barn system? #22
phase 2 is finally complete - roof purlins have been installed. 55 degrees on New Year's eve was helpful. see link below for pics
Barn 4
next steps are installation of support beams for loft floor and installation of metal roof .
was hoping to have a roof over the tractor by Christmas....oh, well, it might be there by spring.
progress reports to follow as progress is made
/ Different Pole Barn system? #23
Very interesting thread guys. I'm building a garage w/ apartment too. Mine is looking to cost darn near 50K tho at 32 by 48 w/ attic trusses. I just got my permit too. I wonder if I can (or could have) saved some money w/ this stuff?
I'm stick framing it b/c that what my builder (father in law) prefers. Composite roof, hardi siding to match the house. Nice big hobby shop.
/ Different Pole Barn system? #24
I was interested in building a 40x60 building using SIPs, then noted that I could get a kit from Menards for a 50x90 building for less than the 40x60 was going to run. Not apples to apples, I know, but this thread has started me thinking from the beginning about what to do. Does anyone have any links or thoughts on why you would want one system over another? I had Menards quote out a 2x6 stick built building vs a pole-constructed and was amazed to see the stick built quoted for less. Is there some newbie barn building guide out there comparing the options?
/ Different Pole Barn system? #25
Looks good, keep the pix coming.
/ Different Pole Barn system? #26
kwTN,
I saw on another post where you've made more progress and added a 12'x24' shed. Any chance we could see additional progression pics (if you have them) to get to the point you are now with the barn?
Also...it appears from the previous pics that you constructed your post by laminating 2"x4"s and 1/2" plywood. True?
Jim H.
/ Different Pole Barn system? #28
The vertical & diagonal posts consist of (3) 2x6s with 1/2" (don't remember for sure) plywood sandwiched in between. The attached pictures are a quick progression from beginning to now. Right now the exterior is being used as a test pallet for the color of the new house currently under construction. The focus is now on finishing the house, 500' driveway and 2500' of fence.
/ Different Pole Barn system? #29
Jim - thanks for the suggestion of doing a search on laminated post. Found lots of threads and info. This website is amazing when it comes to information!
kwTN - Appreciate the pics. Wow...looks like you've got alot of building projects going on all at one time. House looks good. Nice to have a testing spot to try out different color palettes. Sure beats having to repaint after the Mrs decides she doesn't like it once you've finished! ;)
/ Different Pole Barn system? #30
kwTN,
How do you plan to handle the wind loads on the barn?
Leo
/ Different Pole Barn system? #31
not visible in the pictures, there are steel cables running in an x-pattern and from side to side at the top of the vertical posts. I've been in the barn in some pretty heavy winds and it doesn't move. by the time it is completely sided, there will be laminated beams and floor joists for the loft tieing things together even better. Fortunately, the usual at my place is just breezy and 'high' winds are rare.
/ Different Pole Barn system? #32
Thanks for the explanation. Since I live where the wind can reach very high speeds once in a while I have become concerned about such things. When I built my shop the Codes had just changed to require "Design for 120 mph winds on the west side of I-75 and 115 mph on the east side of I-75" ... I live about one mile on the west side of I-75. There is no structure made of wood in the building except from the ceiling joist up! I was required to use 6" steel studs (and steel cross braces for the shear walls) ... so it is well built. It took me 3 months of constant design and change to get a permit. The orginal drawings (Arch) were good for the footing, floor, building foot print and the roof system by the time we got the permit. Again thanks for the expanation!
Leo
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
New/Unused Wolverine 43in Mini Rock Bucket (A65583)
New/Unused...
2004 Chevrolet Silverado 2500HD (A66408)
2004 Chevrolet...
Cat 312 Excavator (A62679)
Cat 312 Excavator...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
