Different emissions
/ Different emissions #1
4tillingdirt
nc
N/A
Will most manufacturers abandon the DPF for DOC?
/ Different emissions #2
As I understand it, DOC is only used in lower HP units due to lower emissions standards as defined by the EPA. At current levels DOC is not effective as a stand alone system in those higher HP engines. I had a DOC system in a NH Workmaster 50 that worked well while I had it. Kubota has elected to utilize a Regen system in their smaller HP diesels. No requirements are needed in 25 HP and under.
So to answer your question...
IMHO as long as the EPA keeps current standards as they are I think the emissions systems adopted by different manufacturers will stay as is.
Reason I say it is that Massey is coming out with new 1700 premium series tractors and they are switching to a shibaura engine and they are not using a DPF like they did on the previous engine. I should have specified 60 hp and under compacts.
/ Different emissions #4
Mahindra uses DOC in their tractors up to 75hp. That's one of their big selling points, the high pressure common rail engine and no DPF regens because they use DOC. DOC functions in a similar way to a catalytic converter with a gas engine. Above 75hp most if not all use DEF (diesel exhaust fluid).
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2008 CHEVROLET IMPALA CAR (A66091)
2008 CHEVROLET...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2022 Kubota 62in Zero Turn Commercial Mower (A66734)
2022 Kubota 62in...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2012 CATERPILLAR AP1000E ASPHALT PAVER (A65056)
2012 CATERPILLAR...
