OP
JRH02
Platinum Member
- Joined
- Oct 3, 2020
- Messages
- 662
- Location
- PNW, canyons and forest.
- Tractor
- Kub B7100 manual; JD410J, JD Diesel 6x4, Woodmizer LT50HD
Me too: PTO 42" tiller, rear blade, cultivator (tines).They are so cool.. Mine came with a roto tiller. I did not know there was a backhoe attachment. If its ok tomorrow i will measure the fuel filter and if you have a spare in stock and measure yours if its the same maybe i can get a part number from you so i can order some. Found some close but not totally correct. After moving here and realizing how handy a hoe would be i bought a used IHI 15NX. another great machine from Japan powered by Yanmar 3 cyl almost the same as the 7100 Kubota motor
I looked for a the backhoe for years. Its model B670 complete with the adapter brackets for the axle housing. The hoe is powered off pump via the PTO. The BH's front brackets attach to the crossmember of the loader. If you don't have the factory loader you'll find or have to make a crossmember.
The fuel filter in the clear holder I use is a Wix 33389 from NAPA.
