Comparison Differences between RX 20 series tractors?
/ Differences between RX 20 series tractors? #1
KiwiBro
New Zealand
Kioti RX7620
There are 66 and 73 HP options in USA and we have a 76 HP option here down under also. Seems to me the only difference is the fuel pump being turned up. Can anyone see any other differences please?
Thanks,
Tony
/ Differences between RX 20 series tractors? #2
Just speculating, but it is most likely due to Emission T4 standards in the US. If engine is listed/rated over 75 HP it falls into another (higher/more stringent) emission rating. Changing the ECU program for fuel injection quantity & timing will change the HP.
You're onto it. We don't have the t4 legal requirement down here. However is fuel delivery the only difference between them? Looks like same engine and chassis. Hydraulic flow rates vary but is that different pump. Can anyone see any differences between the 20 series models?
Same engine for the 66/73/76HP models.
Can anyone help point me to a link detailing the engine IPL's please?
Either I'm not seeing it or some marketing genius at Kioti has decided us plebs don't need to know what the engine differences are or how such difference may influence longevity.
Thanks.
/ Differences between RX 20 series tractors? #5
There could be some additions to the engine that aren't listed besides just turning up the injection pump. Adding an intercooler to cool the intake air provides about 10 HP and then add a turbocharger on top of that will get you some more from the same engine. They may not list those adders to the engine but there is a limit to how much power you can get from just turning up the pump before it starts to pump out unburned diesel.
As for the rest of the Power Train, if it is designed to handle the upper limit then there is not problem with the smaller HP.
Just about all (if not all) manufacturers do the same thing by making around 3 models with the same frame size and components and just tweaking the engine to get what is needed. My 2010 model P7010 LS came in 3 engine sizes 70,80 and 90+ HP. I think the newer models have even more HP in the same frame size.
I've downloaded the service manual and from I can make out there is zero difference between them other than ECU settings. If that is the case, I wonder what the engine life differences are between a 66HP and 76HP model. Maybe so small to be irrelevant?
Also, I don't see many RX 20-series tractors being advertised up there and I can't find any substantial reviews of this series anywhere on the net that I have looked thus far. Does anyone know of any non-marketing (i.e. real-world) owner reviews or discussions about this series of Kioti tractor? Is it just too new for there to be many out there? Not sure I want to be an early adopter and working out any kinks with the dealer.
/ Differences between RX 20 series tractors? #7
They're newer, but not brand new, been around for a few years I think. A few people here have them, and I haven't seen any complaints about them.
/ Differences between RX 20 series tractors? #8
I think SSdoxie is right about the Tier 4 criteria, because the 7320 and 7620 appear to be the same tractor. The 6620 is a slightly smaller tractor in length, width, weight, tire size, etc.. The 6620 does have the advantage in that it can be fitted with a frame mounted backhoe from Kioti, but not the 7320. Although I'm sure an aftermarket backhoe could be found if the need was there.
Take care
870Wing
/ Differences between RX 20 series tractors? #9
What aside from reviews are you looking for? What exactly do you want to use a particular Kioti model/HP to accomplish?
As a for instance, my Yamaha 225HP fuel injected four stroke outboard is the EXACT same engine from 200-300HP. Just different torque and fuel curves, controlled by the brain. Oh, and way more money too for the higher horses. It's the wave of the present and future of engines. My 2015 Toy Forerunner is a 6 cylinder that has larger displacement, more torque and power than did my '011, and again more than my 2007 model, and they no longer offer 8 cylinders. It's the way to save on cost of multiple engines, engineering, manufacturing and efficiency of fuel use.
Must have wide, child-bearing hips, be a fitness fanatic, like pina coladas and getting caught in the rain.
But more seriously, my needs beyond real-world reviews backed by real-world use, are almost irrelevant at this point. For if I can't find enough credible people willing to share their experience with such a tractor series, I'm not about to be an early adopter on the potentially bleeding edge.
Take care
870Wing
Thanks. I did not realise the chassis on the 6620 was different to the 73/7620's. I don't think we get that 6620 here in NZ though, at least not from what I have seen available. However, it looks to have the same engine as the 73/7620.
Sat on one, hood is so high this shorty couldn't see forks on FEL. Was a bit hit and miss changing implements too because couldn't see the FEL pins. Would be OK changing when used to the FEL, which I'm sure wouldn't take long, but I really need to see the tip of my forks when working with logs/trees.
Didn't really take a good look why but the t4 gear may have necessitated a rise in hood height? Not sure how much, if any, operators could raise the seat.
The search continues...
/ Differences between RX 20 series tractors? #13
I think that's just common to these size tractors, especially with cabs... My NX6010 I can see very little she hooking up an implement (including the highly important ends of the quick connect brackets) or using the forks.
Shortness is not an issue for me... I'm 6'5".
Got no probs seeing the forks when using a larger but older Case IH. Will get on a few more new tractors to compare. Hopefully they are not all like this. Sure, we can get used to anything, but a large chunk of my work is with the forks and in less than ideal terrain, so guessing where the fork tips are or trying to stand up each time to see 'em, is not high on my 'want list' when new tractor shopping.
/ Differences between RX 20 series tractors? #15
I can not see most of the loader bucket from the seat of my CK35, same on my neighbors older JD. I think unless the loader is up a few feet, you cannot see the front of the loader on most tractors.
2023 JOHN DEERE 317G SKID STEER (A62129)
2023 JOHN DEERE...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
2019 CATERPILLAR 262D SKID STEER (A62129)
2019 CATERPILLAR...
2014 Ford Explorer AWD SUV (A61569)
2014 Ford Explorer...
