Traction diff lock
/ diff lock #1
easyas123
MF 35x
Hello tractor folk,
I have recently attained my first tractor, a fully rebuilt Massey 35x.
Tried the diff lock today (by standing on the foot pedal), and have lost the ability to steer. It doesnt seem to be disengaging.
Any tricks or tips before we start surgery?
Any advice gladly accepted.
Thanks,
Don.
/ diff lock #3
Hello tractor folk,
Thanks,
Don.
1] Youre not supposed to stand on the pedal - merely push it with moderate force. When the gears line up [due to 1 wheel rotating more] it will engage and lock the axles together. 2] The pedal is spring loaded to the disengage position and should disengage after you release pressure as soon as axle forces equalize. Try steering gently one way and then the other. This should remove load on the lock and it should pop out. If not try pulling the pedal while doing it. Also check the linkage for binding. Hopefully there is no internal damage from standing on the pedal.
larry
/ diff lock #4
Drive slowly while cutting the wheels back and forth as you pull up on the pedal. It should release then.
/ diff lock
all sorted now - thanks for your help, much appreciated. Don
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2021 CATERPILLAR 289D3 SKID STEER (A65053)
2021 CATERPILLAR...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2014 Ford F-150...
2017 Ford F-150 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
PALLET OF JOHN DEERE WEIGHTS (A64278)
PALLET OF JOHN...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
