Traction diff lock
/ diff lock #1
easyas123
MF 35x
Hello tractor folk,
I have recently attained my first tractor, a fully rebuilt Massey 35x.
Tried the diff lock today (by standing on the foot pedal), and have lost the ability to steer. It doesnt seem to be disengaging.
Any tricks or tips before we start surgery?
Any advice gladly accepted.
Thanks,
Don.
/ diff lock #3
Hello tractor folk,
Thanks,
Don.
1] Youre not supposed to stand on the pedal - merely push it with moderate force. When the gears line up [due to 1 wheel rotating more] it will engage and lock the axles together. 2] The pedal is spring loaded to the disengage position and should disengage after you release pressure as soon as axle forces equalize. Try steering gently one way and then the other. This should remove load on the lock and it should pop out. If not try pulling the pedal while doing it. Also check the linkage for binding. Hopefully there is no internal damage from standing on the pedal.
larry
/ diff lock #4
Drive slowly while cutting the wheels back and forth as you pull up on the pedal. It should release then.
/ diff lock
all sorted now - thanks for your help, much appreciated. Don
2014 International PayStar 5900i T/A 24ft Flatbed Truck (A64194)
2014 International...
2018 CATERPILLAR 307E2 EXCAVATOR (A65053)
2018 CATERPILLAR...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
2023 Chevrolet Express 2500 Cargo Van (A61573)
2023 Chevrolet...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
