Diesel Vapor Lock
/ Diesel Vapor Lock #1
ford351c
I have a Ford 1210. After mowing for awhile the engine will start to bog down sometimes to the point I have to stop and wait for a few seconds for the rpm's to work thier way back up. Then it will run fine for a few minutes and do this again. It has never done it before being run for 20-30 min. Only happens after that. Seems to happen more frequently if it is hotter out. Dosnt do it the winter when plowing snow at all (of course not mwoing and mower is removed). I am not familliar with diesel engines, but would liken this to a vapor lock condition in a gas engine. Anybody know what what be happening here ????????????????????
/ Diesel Vapor Lock #2
Fuel filter clogging? and restricting fuel flow?
Jim
/ Diesel Vapor Lock #3
Not vapor lock.. but deffinately sounds like a fuel delivery issue.
Check your water traps.. When is the last time you changed fuel filters.. might also check fuel tap at the tank.
Soundguy
/ Diesel Vapor Lock #4
you might check to see if your fuel tank is vented through the cap,some of the mahindra 00 series had a defective cap causing the same problem.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
(INOP) 1996 CASE 580L BACKHOE (A59823)
(INOP) 1996 CASE...
iDrive TDS-2010H...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2022 Ford Explorer AWD SUV (A59231)
2022 Ford Explorer...
