diesel pickups
/ diesel pickups #81
</font><font color="blue" class="small">( So I need a F350 crew cab 4X4 dually with a juiced Cummins with the Allison transmission behind it. )</font>
That's just what I've been saying ever since GM came out with the Duramax and Allison. /forums/images/graemlins/laugh.gif
/ diesel pickups #82
I had Ford's before, and really like them. My comparison is to the '80 and '89 gasser F250 4x4's I had, and a friends '99 PSD. I liked them all, but my '01 Ram handles and drives as good. I have ridden in a newer Ford, and didn't find it any better than my Ram(about even...).
The only thing I would do different in a newer truck, is get a 6spd stick, and taller gearing. I really don't need the 4.11's I have. I have towed about 10klbs. The 4.11's were nice for that, but that is the exceptioon not the rule. I take a double whammy in mileage for the auto and 4.11's.
My '89 F250 did, however, handle MUCH better after I threw away that silly IFS they used and put a solid axle up front...
/ diesel pickups #83
Some of the negative comments about diesel's in this thread are true for the old ones, but not so for the new generation of diesels.
Let's take the common diesel complaints one by one:
1) Poor acceleration: True of an early 90's 7.3L IDI Navistar diesel like those in the old Fords. My old non-turbo ford is a dog in terms of acceleration. The new dodge generates 325 hp and 600+ ft-lbs of torque stock. In comparison a stock mustang generates 210 hp and 240 ft-lbs. The only thing that gives the mustang a prayer is its about 1/2 the mass. But then again it has a towing capabilty of 1000 lbs and the dodge can be as high as 16000 lbs.
Add a chip to a new diesel for a couple of hunderd bucks and you can smoke the tires and the mustang.
The other brands have comparable output power levels.
2) They smell and generate smoke. Very true of the old ones. My 7.3L ford rolls the black smoke out the back when hauling a trailer. The new dodge generates no smoke that I can detect.
Also the old one smells, the new one does not except after oil changes with rotella. Even that smell is very minor and it goes away after about a week.
These new ones have a cat converter.
3) The cost is higher. True the diesel may add as much as 20% to the cost of the truck. But you will likely get 30% more miles out of the diesel so the price is fair. Resell value is also much higher in a diesel with equivalent miles to a gas burner.
4) Cost more to service. Not so. Sure the dealer or lube place will charge 10-20% more to service the diesel. But the dodge schedule call for more miles between changes so I think it's a wash. Even if you do it yourself the oil cost and filter cost is higher than the average gas burner but the frequnecy of changes is lower.
5)Loud. Well the first generation dodges and my old ford are very loud the new ones are not.
At idle they are louder than a gas truck, but under load the diesel is actually quiter. Just the other day a noise caught my attention when I passed another truck. It was a gas burner pickup struggling to climb a hill as I blew by him.
I am not saying that a diesel is the solution for everyone, but I think the popularity will grow once people realize the advancements that have been made in diesel engines in just the last few years.
Fred
/ diesel pickups #84
GM has paid out more in warranty repairs on the Allison since it's introduction the either ford or Dodge has on their automatics. (per JD Powers) GM now de-fuels their diesel in first and fifth gear to prevent this damage. The 1000 series Allison has allot of potential, but GM doesn't seem to use it right.
I like your idea of the "mixed breed", it is available. The F650 I believe has a Cummins/Allison option available. Near $65K though. /forums/images/graemlins/blush.gif
edit:
BTW Dargo- Detroit Diesel is now part of Daimler/Chrysler, that's why GM went to the Isuzu motor.
/ diesel pickups #85
<font color="red">The F650 I believe has a Cummins/Allison option available. Near $65K though.
</font>
I just got off the phone with the dealer and ordered a new F-650. It will have the Cummins motor with a 6 speed Allsion automatic. Retail price was $67,922. My price was $54,918. You had a choice of motors between the powerstrok, cat, or cummins.
/ diesel pickups #86
Since I obviously didn't know you could get the best of all worlds all in one package, it is obvious I don't know what the F-650 is. /forums/images/graemlins/confused.gif Is it still a "pickup" like we know one? Any links to where one can be seen? It doen't sound like you can possibly dream up a better setup!
/ diesel pickups #87
I have an 01 H.O. Dodge, and just replaced the complete exhaust system. The original was rotting out in several areas. My fault though as the truck really never warms up.. In the moring a seven mile trip to get mail, milk, and return back home.... I bought it new in early 01 and only have 46K on it.... I replaced the factory exhaust on a recommendation from one of the snow plow nets I am on. 4" stainless from the turbo back.. Thought it was loud prior, now it is really loud, and today hauling my tractor, L 48 TLB Kubota on a Bri-Mar 12/28 trailer, both very heavy in their own right, and it is even louder... Third generation has forced rail fuel system and is quite a bit less decibles than mine...
/ diesel pickups #88
Dargo- A 450 and 550 are based of the HD pickup type truck, only heavier: 19.5 wheels, beam axle front suspension, ect. An F650 is like a "Top Kick" or "Kodiak"; a medium duty truck, GVW up in the 20-25,999 lb range. You 'can' put a pickup box on the back of one of them, but usually a larger load platform is used (stake-bed, van body, etc.). They can also be had in 4wd, but andother $10k, I think would be in order for that.
Check this site for this type of thing! /forums/images/graemlins/grin.gif
/ diesel pickups #89
av8 is correct. some are flatbeds, some are normal pickups and some are dump trucks.
/ diesel pickups #90
Holy cow!! That's awesome. However, it sort of kills the idea for me. A wee bit too much truck; even for me. /forums/images/graemlins/shocked.gif Especially since my plan would have been to put my wife in it as her main vehicle for a year or two. I had to sell her Suburban because it was "too big". I don't think I could talk her into driving a F-650. /forums/images/graemlins/frown.gif
/ diesel pickups #91
Dargo,
Here is what the one I am buying will look like.
/ diesel pickups #92
It's to pull this trailer. I could have gotten by with the 550 but you can only get the powerstroke in the 550. I wanted the cummins and the 6 speed allison. To get that you have to go to the 650 Crewzer. Price wise it was only a little more.
/ diesel pickups #93
That looks like it will be a great setup for towing, Richard. I can't wait to see pictures of your actual truck when you get it.
Lawrence
/ diesel pickups #94
Some folks at the local Elks Lodge, where my Boy Scout troop meets, has a Ford just like that. They have a 5th wheel that appears to be a mid 35ish' long that they tow. Appears to be a much better tow rig for something that big, compared to the 3/4 tons I see running a 5th wheel that big around here...
Harder to park when you are away from the show/competitiion and doing some sight seeing or local grocery shopping though /forums/images/graemlins/grin.gif
/ diesel pickups #95
/forums/images/graemlins/cool.gif Now, that's a truck! How long are you with your truck and trailer? With only my 25' gooseneck trailer behind my 1 ton extended cab dually Dodge I'm almost 57'. From your picture, it looks like your trailer is over 40'. /forums/images/graemlins/shocked.gif With the gates I set up at the entrance to my property (too close together now in hindsight), I can just barely make the turn if I drive halfway into a deep ditch across the road. I actually had to move an eye bolt on one gate post (used when just chaining off the entrance) because I needed the extra 1 1/2" of opening. /forums/images/graemlins/blush.gif
Good luck with your new ride!
/ diesel pickups #96
<font color="green">
Here is what the one I am buying will look like. </font>
Doc,
Ahh, nice. But will you be getting it in <font color="green"> JOHN DEERE GREEN? </font> <font color="yellow">With YELLOW wheels? </font>
/ diesel pickups #97
Dargo,
The trailer is 37 foot long on the floor, which is 45' long counting the front gooseneck. I'm not sure what the total length will be. The trailer empty weighs 14,700. With the horses, water, etc. we were at almost 20k. The Dodge pulled it ok but I don't think it will last long pulling that heavy of a load up and down the road every week.
/ diesel pickups #98
<font color="red"> Harder to park when you are away from the show/competitiion and doing some sight seeing or local grocery shopping though </font>
Robert,
Yea I thought how we could go to the amusement parks and other things at these shows and such. Heck by the time you get there, I usually drive all night getting to where we are going after working 16 hours, get everything done, run, take care of the horses, I don't feel like doing anything!!! I don't think I've unhooked the truck from the trailer two times the last three months and one of those was to trade the old trailer for this new one. /forums/images/graemlins/wink.gif
/ diesel pickups #99
Richard,
Nice truck and trailer.
Did you have to get the new truck now that your daughter is a rodeo star? /forums/images/graemlins/grin.gif
Later,
Dan
/ diesel pickups #100
Nice combination Doc.
Is that trailer your birthday present of a few years ago?
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Egon
2014 Grand Caravan (A62679)
2014 Grand Caravan...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
UNUSED WOLVERINE 3PT QUICK HITCH RECEIVER (A64281)
UNUSED WOLVERINE...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
3pt 4' Disc Harrow (A64119)
3pt 4' Disc Harrow...
