(Diesel) JD 430 Lawn Mower not starting... (diagnosis???)
   / (Diesel) JD 430 Lawn Mower not starting... (diagnosis???) #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I've got this 430. Essentially, runs like a top. Old battery so needs jumped every now & then if it's been sitting.
Cut yard say, 2-ish weeks ago and all is well. Drove it to it's parking space and turned off. Other day, jumped on to cut lawn. Nothing. No problem, it's got a weak battery so pull wife's car alongside to jump start.
Long story short, the engine (with wife's car assist) will crank like a bandit BUT, doesn't start. It has NEVER done this. Not noticing any (hardly any as there might have been a wisp) smoke coming from exhaust, I wondered if it was getting fuel.
Cracked one, then finally cracked all the injector lines open to crank over. Here's where my ignorance is going to get me. My OTHER diesel toys are significantly larger than this mower. I see fuel squirt out of those but, they're larger engines.
I DID see some (what I'll call spittle) coming out of the injector but what I don't know is, is that 'spittle' on ratio, similar to what the IH or JCB might do, or is it indeed, spittle and it's not getting enough fuel to do anything. (just how much fuel would an engine like this spit out if you crack the injectors open)
I'm guessing spitting drops out isn't enough and if this is accurate, I'm wondering if I should look at the pump. If drops spitting out IS enough, then maybe look elsewhere (but where)...
There is ZERO sputter, zero backfire, (essentially) zero smoke, just the little engine being buzzed around by the starter.
Any thoughts?
To reiterate, roughly 2-ish weeks ago, it started and ran like a bandit until I turned it off and walked away. Absolutely zero noticiable issues while using it.
Fortunately I have a Woods 6' finish mower so I pulled that out of the woods (no pun intended) and got things cut with it but I rather use the 430!
   / (Diesel) JD 430 Lawn Mower not starting... (diagnosis???) #2
Did you check the glow plugs ?
(quick answer: no)
if the glow plugs are activated by turning key reverse, ive never done it, never needed it...always fairly quick starter
   / (Diesel) JD 430 Lawn Mower not starting... (diagnosis???) #4
I believe you should get a squirt of diesel from the injector lines.
Do you have a voltmeter or test light to check for power to the fuel shut off solenoid on the injector pump? If that circuit fails it will crank all day and do nothing.
   / (Diesel) JD 430 Lawn Mower not starting... (diagnosis???) #5
Does the glow plug light come on?
It should come one for a few seconds, even when warm.
Is the solenoid on the fuel pump pulling in? The solenoid has to pull the lever on the pump or it doesn't pump fuel to the injectors. If it's extemded and doesn't pull in when the switch is turned on, check the fuses.
hadnt thought about the shutoff....will look
   / (Diesel) JD 430 Lawn Mower not starting... (diagnosis???) #7
(quick answer: no)
Turning the key backwards is just for checking the functionality of the dash lights.
   / (Diesel) JD 430 Lawn Mower not starting... (diagnosis???) #8
Dribbles only work for teething babies. Solid fuel flow pops the injector pintle, not dribbles.
   / (Diesel) JD 430 Lawn Mower not starting... (diagnosis???) #9
Based on my JD diesel backhoe, I suspect the safety lockouts. If the wiring isn't fully convinced everything is in true neutral, no starting for you!
But for me it won't try to turn the motor on - it acts like a bad battery (it isn't). Worth a shot though - wiggle all the stuff that's supposed to be in neutral or off for the engine to start.
   / (Diesel) JD 430 Lawn Mower not starting... (diagnosis???) #10
We have a John Deere 430 tractor. I notice as it got older, it wouldn’t start with throttle all the way down (idle position). I moved the throttle to 1/3rd and it starts right up.
Finally got to getting my hands dirty.... Here's the rest of the story.
Working backwards, the solenoid wasn't working so it wasn't getting any fuel. It will move (by hand) and will move when directly energized. Kept looking. "under the dash" are two, very difficult to get to without pulling a side panel off quick wire disconnects.
Though I didn't count, one seems to be a 10 wire connector and the other is maybe a 4-wire connector. Lots of dirt packed inside the individual wire holes. Can't get to them easy enough to actually pull apart so as it happens, I have some electronic contact cleaner (spray).
Several soaks & blasts of air later, the solenoid now works. Seems it had a dirty contact in there. Probably still dirty, just not quite as dirty!
Solenoid moves as it should with key turned, mower fired right up.
   / (Diesel) JD 430 Lawn Mower not starting... (diagnosis???) #12
Good going. Glad that you figured it out and let us know how you fixed it.
Richard
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2019 CATERPILLAR 304ECR EXCAVATOR (A60429)
2019 CATERPILLAR...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
(2) TW 30 FORD WHEELS (A60432)
(2) TW 30 FORD...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
