Oil & Fuel Diesel Fuels
/ Diesel Fuels #1
Piperflyer
USA
Kubota3030HST
Does it make a difference if your not using your equipment that much with diesel fuel stored in the tank.
/ Diesel Fuels #2
I could be wrong but I am reasonably sure that diesel fuel stores much better than gasoline, I have used diesel from a can that had been stored two years and it was fine. That is about all I know on the subject.
/ Diesel Fuels #4
hi it's ok to store you tractor with diesel because the diesel does not go bad as fast as gas.
/ Diesel Fuels #5
The fuel itself does not break down as fast as gasoline, but be aware that bacteria will grow in diesel that has moisture in it. Those little buggers will stop the flow if you let them move in.
/ Diesel Fuels #6
If you're not going to use the tractor much you should fill the tank. This will keep water from condensation out of your fuel. Another thing to keep in mind if you store it for long periods especially if you fill in the summer and go to use it in the winter is cloud point.
What is the Cloud Point of Diesel Fuel
There are also comments about algae growth, but I've only found discussions on what it is by companies that make algaecide so I don't know if that is a real problem or a product looking for a problem.
In either way, I've not had any problem with fuel even when stored for more than 6 months, probably closer to a year. Just be sure to change filters on schedule.
/ Diesel Fuels #7
keep em full to prevent misture from condensing.. and treat tanks with biocide and stabilizer. same for tractor tank too.. run it some to get that circulated into the injector pump as well.
soundguy
/ Diesel Fuels #8
I am sure it exists, I just don't know where. I have spoken to numerous farmers in my area who store fuel for long periods of time and whose tractors don't move all winter and none of them use it. My father in law owned a fuel distributorship an d he did not recommend it. I have run diesel tractors for many years and on a couple of occasions not moved a particular tractor for over a year and not run into problems.
I have seen posts on here where people have experienced it so maybe they can provide some information.
/ Diesel Fuels #9
down in our tanks here in florida it can be an issue where you get moisture inthe fuel. sure HAVE to use a biocide or you get black gunk that plugs up the filters and taps..
soundguy
/ Diesel Fuels #10
Hop on over to 'Oil, Fuel and Lubricants' , Oil, Fuel & Lubricants - TractorByNet.com
and you will find lot's of info on that subject, as well as others.:thumbsup:
It ain't just algae that you need to be concerned with nowadays.
/ Diesel Fuels #11
I picked up a 30 gallon 'natural' colored poly barrel to store diesel fuel for use in my tractor. The 'natural' color is white, not quite clear, and I used it so I could see the level in the barrel. Stored outside, used very little fuel due to the efficient little tractor, and six months later I had floaties in my fuel. Since I wanted a filter in the dispenser line, this was a great time to make it happen. Administered biocide and installed filter, pumped fuel through the filter and back into the barrel for a while, and haven't had any trouble since. I don't think I had a water problem, no water is evident in the barrel. It did have plenty of exposure to sunshine. Keep your fuel dark and dry for best results. I dose with PS biocide and PS white bottle when filling the barrel. Stored fuel 12 months later still looks and works great.
/ Diesel Fuels #12
Well that would have been my next question, thanks JMynes. I wonder if the problem(s) exist or occur just as quickly with different types of diesel, let's say gas station diesel vs ag diesel vs bio, etc.
/ Diesel Fuels #13
No expert here, but from all I have read/heard/observed, over-the-road diesel and off-road diesel differ mainly by the dye added to the off-road. However, there may be differences in sulfur content. I defer to the experts.
I have no experience with bio, but according to the link below, it has a shorter shelf life.
"Bio blends also have a shorter shelf-life than conventional diesel with the lower BX/BXX level having the longer shelf-life."
Wisconsin Department of Commerce: Storage Tank Program - Converting to biofuel storage -
Steve
/ Diesel Fuels #14
My experience was with gas-station diesel. I try to fill the barrel in November-December for snowblower season, and top it off before the Summer blend hits the street. I don't fill the barrel in the summer time, I don't want to get caught in December with a full barrel of Summer blend.
/ Diesel Fuels #15
I found on here years ago a page about all of the weights of oils and what they mean and I didn't save it and now I cannot find anything like it.......For instance 10w30 VS 5W040
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
TAYLOR WAY 16' DISC HARROW (A64276)
TAYLOR WAY 16'...
