Diesel Fuel & Storage Questions
Status
Not open for further replies.
/ Diesel Fuel & Storage Questions #121
cowboydoc, how do your air vents prevent moisture from getting in? I am talking about the moisture in the air (humidity).
This is a standard oil tank vent with screen, gage, and vent alarm combination. It won't do a thing to prevent the oil tank from breathing and inhaling moisture laden air.
/ Diesel Fuel & Storage Questions #123
Where would you get a vent/guage like that?
I got mine from Famous Supply of Akron but I'm also confident the TSC would have them.
/ Diesel Fuel & Storage Questions #125
<font color="blue">1*I also have plenty of room in my unheated pole barn for a steel tank
I have an idea of placing the tank in my basement area since it is heated
2* is home heating oil the same as off road diesel?
</font>
1* I don't like the idea of storing flammable liquids in side of any building much less a heated one.
2*It is here.
How do you make on road diesel? ~~ Take clear diesel and add highway tax to It.
How do you make off road diesel? ~~ Take clear diesel and add red dye to it.
How do you make Fuel Oil or home heating oil? ~~ Take Clear diesel dump it in your tank and burn it in your furnace / or Take Clear diesel dye it red dump it in your tank and burn it in your furnace.
/ Diesel Fuel & Storage Questions #126
Thanks for the heads up.
/ Diesel Fuel & Storage Questions #127
It's great when a 14.5 month old thread is reopened with a post containing such valuable informaton. Thank you.
/ Diesel Fuel & Storage Questions #128
</font><font color="blue" class="small">( Holzster,
Dealers around here, don't charge extra, but they do have a minimum delivery amount. )</font>
In my neck of the woods the minimum delivery amount is 150 Gallons but there is no minimum purchase amount.
/ Diesel Fuel & Storage Questions #129
</font><font color="blue" class="small">( Jerry this 275 gallon tank will be inside my pole barn and I don't want the 2000 pounds of fuel high enough off the concrete that it would take to fuel my TC-40D. I would rather keep the tank low on the deck and add the electric pump. In my case it's just a personal preference. )</font>
In my case it's a lot simpler to simply roll the tank right off the tail gate onto the shelf than it would be to hoist it up high enough to work for a gravity feed.
/ Diesel Fuel & Storage Questions #130
</font><font color="blue" class="small">( <font color="blue">If you break off the fitting on the bottom of the tank, there is no stopping the oil from emptying from the tank.</font>
That makes sense. I'll still take my overhead and not mess with a pump any day. )</font> <font color="purple">How do you get the tank down out of there to fill it then put it back up there after it's full ? ? </font>
Status
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
Kubota B2301 (A53317)
SET OF 45" PALLET FORKS (A60430)
SET OF 45" PALLET...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
