Oil & Fuel Diesel Fuel Additives
/ Diesel Fuel Additives #1
RhallVA
VA
Do you folks use any additive to your tracotr fuel or do you use straight #2 diesel fuel (like for a car)?
The last tractor I used on any regular basis needed an additive to replace the sulphur that was taken out of car diesel fuel. Is this not necessary for newer Kubotas?
Thanks!
/ Diesel Fuel Additives #2
I use Power Service fuel conditioner but mostly to prevent gelling in the winter.
No clue about sulfer /w3tcompact/icons/smile.gif
/ Diesel Fuel Additives #3
during the summer months..I use no additive at all..but in the winter months here in New Hampshire..around about October..I will cut my diesel by adding kerosene to the fuel..keeps it from jelling..once I am sure the fuel stations have cut their supply..I no longer add kerosene to my fuel..kerosene will not hurt the motor on my B7500..in fact..it can run on straight kerosene
So I can use the same deisel fuel form the gas station that a deisel car would use?
Thanks!
/ Diesel Fuel Additives #6
Yes the same deisel you would put in a car is what you can put in your tractor. I would suggest you use the "off road" deisel it is about 10 cents cheaper. You should be able to find plenty of stations that sell it.
/ Diesel Fuel Additives #7
Last year our diesel fuel was jelling during an extended freeze in our diesel truck. Stanadyne did the trick. I've carried over using it in the summer months. I get better mileage in our truck over summer and winter, no fuel jelling, and we seem to get better overall performance.
Look through this page and those associated with it at:
http://www.dieselpage.com/addtest.htm
Try checking your oil with e free test kit from:
http://blackstone-labs.com/index.html
/ Diesel Fuel Additives #8
Likewise, I've used Stanadyne in my diesels and been extremely happy with it. No jelling at all...and we have some wicked winters. My only complaint about the stuff is I've been unable to find a source except for the annual farm and yard show in Barre, VT. So I'm stuck buying it by the case once a year. /w3tcompact/icons/blush.gif
Pete
/ Diesel Fuel Additives #9
i don't use any additives in my fuel, don't think u need then unless u have EXTREME weather conditions. this is just MHO
/ Diesel Fuel Additives #11
I haven't had any experience running my tractor in the winter yet, (we haven't had real winter conditions in my part of the country this year). One of my areas of responsibilities in my company is fuel sales to truckers. I spoke with the lab where we get our fuel tested and they told me that the most common problem with diesel fuel in the winter is water contamination. And chances are if you have problems with water in your fuel, its been gathering in your tank all summer. Water is heavier than the fuel so during the summer you don't really notice; but when the temperature drops the water actually starts to rise and "mix" with your fuel which results in water in your lines and filters.
Gene
/ Diesel Fuel Additives #12
In general, no.
Heet is alcohol, and alcohol emulsifies water in fuel. That's not what you want. You want the water to collect in a low place in the fuel system so it can be drained away. The fuel filter looks to be the low point on most Kubotas and water should collect there. Change the filter on a regular basis and you shouldn't have any problems, unless your source of fuel is water-contaminated.
more info coming soon! (A61569)
more info coming...
Hurricane Power X3 Walk-Behind Debris Blower (A61572)
Hurricane Power X3...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A63569)
2008 PROGRESSIVE...
ATS ME18 Mini Excavator (A64047)
ATS ME18 Mini...
2019 FREIGHTLINER CASCADIA CA113DC 6X4 T/A DAY CAB TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
