Did you ever notice?
/ Did you ever notice? #1
jrepp
North West Louisiana
Kubota L5030HSTC
When I only had one attachment I always had the one I need to use attached. Now that I have more than one I never have the correct one attached.
/ Did you ever notice? #2
Yes. That always seemed to be the case with our 3pt hitch tractor. That is why I purchased our Power Trac tractor. /forums/images/graemlins/wink.gif Now, if I don't have the correct attachment on, it only takes 15 seconds to change and I don't have to get off the tractor with the Power Trac's quick attach system. If I need to use a powered attachment, then it takes 30 seconds to change because I have to hook up two hoses. (See a 15 second video here of me changing attachments. That's all it takes.)
If I still had a 3pt hitch tractor for field plowing and such, I'd definately purchase a quick hitch system. I can't see operating without one now that I've used one.
/ Did you ever notice? #3
The best way to fix that is to have a tractor for each implement. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Did you ever notice? #4
That is certainly true with a 3pt hitch. That makes each attachment cost $15000. With the Power Trac, only one or two (one for the wife) tractors are needed.
Bob Rip
/ Did you ever notice? #5
</font><font color="blue" class="small">( When I only had one attachment I always had the one I need to use attached. Now that I have more than one I never have the correct one attached. )</font>
I did till I got this set up.
BX23 that I leave FEL BH & MMM on.
66 Bolens with front blade
67Bolens with rear tiller.
Power craft and 46'' mower deck.
/ Did you ever notice? #6
I try to get as much done between 3 pt. change outs as possible.
Switching implements uses up very little of my time.
/ Did you ever notice? #7
</font><font color="blue" class="small">( </font><font color="blueclass=small">( When I only had one attachment I always had the one I need to use attached. Now that I have more than one I never have the correct one attached. )</font>
Power craft and 46'' mower deck. )</font>
So like Larry, do you mow with your backhoe on??
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
1994 Aeromax Semi Truck (A66285)
1994 Aeromax Semi...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2002 Ford F-250 Service Truck, VIN # 1FTNF21L52EB33349 (A65563)
2002 Ford F-250...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
