did i screw up?
/ did i screw up? #1
jmt1271
Platinum Member
MO
Kubota L2501
i had my dealer fill my tires when i bought my 3520. turns out the local co-op filled them. i think they used a methanol/water mixture. is this okay? should i use something else?
/ did i screw up?
/ did i screw up? #3
That is what I have in mine. Don't think you screwed up, unless you wanted something different and didn't tell them.
Probably could have had the beet byproduct, Rim Gard. Heavier but more expensive. Also, calcium chloride, which is heavier and likes to cause rust of the rim. Anti-freeze which some don't like as they are afeered a leak will cause an animal to want to drink it and die. I like the windshield washer fluid which I assume is what you have.
/ did i screw up? #4
/ did i screw up? #5
Methanol/water is what I have in mine, done by the dealer.
You can also use antifreeze solution, calcium chloride solution or beet juice. All these have their pluses and minuses.
Ralph
/ did i screw up? #6
Ralph
/ did i screw up? #7
If the local co-op filled the tires, they probably used whatever is most popular with the farmers in your area. In my part of the country, a lot of farmers use just plain water since it isn't too likely to freeze and/or they don't plan to use the tractor if it's ever that cold. I've had them tell me it doesn't hurt for them to freeze as long as you don't move the tractor until the ice is thoroughly melted.
/ did i screw up? #8
/ did i screw up? #9
Most of the dealers in my area have used Methanol in tires for about 30 years.
/ did i screw up? #10
/ did i screw up? #13
</font><font color="blue" class="small">( It'll taste nasty and give you a bad belly ache )</font>
When did this post turn into a discussion about scotch /forums/images/graemlins/grin.gif
/ did i screw up? #14
2022 John Deere 7R 210 Tractor (A63111)
2022 John Deere 7R...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
2025 Fendt 1167 Vario Tractor (A63111)
2025 Fendt 1167...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2015 Volvo L30GS (A62180)
2015 Volvo L30GS...
