Diabetes
/ Diabetes #542
Since March 2024 very happy with results much easier to follow levels and keep under control
/ Diabetes #544
Type two diabetic diagnosed 2002 average 550 back then. A1C last month 6.6
/ Diabetes #546
I have gone thru 30 different pucks so far
/ Diabetes #548
Yes two one my fault
/ Diabetes #549
The early 6's I did very well with but the recent ones over the past 6 months, mostly flailed on day 8 or 9. Seems that decom had changed them. Now they've improved again and usually work for the 10.
/ Diabetes
How are you doing Buppies now?
I worry about you getting low blood sugar and out in this high heat.
lots of sports drinks?
if your levels are off, then what?
(am hoping not to personally find out...)
I bet that monitor has saved a lot of lives.
/ Diabetes #551
Average numbers 132 right now antibiotic pretty rough on me presently
/ Diabetes #552
My CGM. You can also see my hernia incision scar! (lower right)
/ Diabetes #554
The last two have gone full ten days
/ Diabetes
for those of us who don't have one, can you explain the ten day period? What lasts that long?
/ Diabetes #556
The monitor as shown in ArlyA picture
/ Diabetes #557
Any of the members using Tandem? They released a new site called Tandem Source. While I hate change it showed a lot of information and wasn't bad once learned. Just recently when I click on it it just goes to a blank screen. Wanted to blame my old computer but on a much much newer system no change. I can still log into the old platform(t:connect). Within Tandem it shows that all systems operating correctly. No place to email questions that I have found. Just curious if anybody else experiencing same issues.
Main screen
When I click on Try Tandem Source
/ Diabetes #558
Its the length of time the sensor in your skin will, or suppose to last. Does that make sense? You need to change them every 10 days.
/ Diabetes #559
Dexcom G7 sensors last ten days, and then give you a twelve-hour grace period before they shut down. It is programmed in and based on most insurance covering thirty-day supply increments.
The old G5 and G6, sensors lasted seven days, (but you could trick them into restarting). The seven-day increment didn't work well with thirty-day prescriptions. Four sensors lasts 28-days, five sensors lasts 35 days. Similar issue with a 90-day prescription, 12 sensors lasts 84 days, and 13 sensors lasts 91-days. And most insurance would only cover thirty-days or less, or 90-days or less, and wouldn't let you refill until you had less than a one-week supply left.
2023 John Deere 317G Compact Track Loader Skid Steer (A64553)
2023 John Deere...
1996 Aspen T/A Pump Trailer (A64194)
1996 Aspen T/A...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
(9) STAMPED INTERNATIONAL FRONT WEIGHTS (A64278)
(9) STAMPED...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
