ArlyA
Super Star Member
- Joined
- Mar 18, 2016
- Messages
- 14,537
- Tractor
- Outlander1000 6x6, Ego lawn mower and shopping for tractor
How long have you been using one? Results?Same here ArlyA
Type 1, 2? A1c?Since March 2024 very happy with results much easier to follow levels and keep under control
How many units have you went through? I've used CGM's for many years. Started with a dexcom 5.Since March 2024 very happy with results much easier to follow levels and keep under control
The early 6's I did very well with but the recent ones over the past 6 months, mostly flailed on day 8 or 9. Seems that decom had changed them. Now they've improved again and usually work for the 10.Yes two one my fault
How we doing there Buppies's? I'm finally getting 10 days life cycle out of mine so DEXcom must have improved the formula.Average numbers 132 right now antibiotic pretty rough on me presently
Its the length of time the sensor in your skin will, or suppose to last. Does that make sense? You need to change them every 10 days.for those of us who don't have one, can you explain the ten day period? What lasts that long?
Dexcom G7 sensors last ten days, and then give you a twelve-hour grace period before they shut down. It is programmed in and based on most insurance covering thirty-day supply increments.Its the length of time the sensor in your skin will, or suppose to last. Does that make sense? You need to change them every 10 days.
