Deutz diff. lock
/ Deutz diff. lock #1
Jimmy Joe
Medford Wisconsin
I see Deutz has differential lock on both axles on their smaller tractors, not sure on the larger ones. Sounds like a nice feature, do any of the other compact lines offer this? How are the Deutz compacts? Anybody own one?
JJ
/ Deutz diff. lock #2
The larger tractors have differential lock on both axles as well. Also like the 4 wheel breaking. I don't have a loader on my Afroplus 87 but I bet it would be a great loader tractor with the shuttle and "stop and go". Never use the clutch pedal except to start the engine.
/ Deutz diff. lock #3
Deutz compacts are really more farm tractors than compact tractors. Our market for Agrokid models is vinyards where they need small but heavy, 50hp in a 30hp size chassis and with features you normally only see on larger farm tractors. For example, front, mid and rear hydrualics, front PTO and rear 540/540E/1000/1000E PTO, Front and rear 3 point hitch, 4 wheel differental lock ect, ect. The only thing they dont share with the larger models is 4 wheel brakes.
Buck
/ Deutz diff. lock #4
Buck
My dealer had one of the 50HP models back in the summer. I had no idea it had that much HP until he showed me the spec sheet. Very nice cab on such a small tractor. I commented to him that the hydraulic filter was larger than the tractor. (grin) It's a very small package of power. Engine and hydraulics.
Just finished 3 days of deep subsoiling with my Agroplus. Useing a cat. 2 jd subsoiler, single shank. These fields hadn't been touched since 1968. (been in fescue pasture since then) Had 8 drought years out of the last 10 and soil was "very tight". Used 4 wd and ran the subsoiler at 29 in. depth. Was very impressed with the speed I could run. Before I got the 87 I used a 64HP Long and a 574 IH for this work. Could run about 2 mph with 22 in. of depth. The Agroplus 87 handled it well at 4.5 mph. Used 1.8 gph fuel with a constant load. When pulling a side slinger spreader loaded with 5-6 tons it uses 1.2 gph. It's a fuel sipper for that kind of HP.
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
2R ROTARY HOE (A63291)
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
Tennant 7400 Compact Industrial Floor Scrubber (A61572)
Tennant 7400...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
