Deutz Compression Test
/ Deutz Compression Test #1
OpenSourceEcology
Missouri
LifeTrac
I'm trying to do a compression test on a friend's Deutz-Allis tractor. It has a BF4L913 engine. Does anybody know of an adapter that fits in the injector bore for this engine? Its a mid-80s tractor. Thanks.
/ Deutz Compression Test #2
For Deutz, you might want to look into MEMO Corporation. Nice people to deal with. Don't give them your E-Mail though, or you will never stop hearing from them.
Tried calling memo but they didn't know of an adapter. Called Foley Engines in MA and they said they no longer carry an adapter for the 913 but that the Harbor Freight kit has one that works. I'm gonna try it and maybe one will work.
The harbor freight kit does have an adapter that works. Got 160-180psi on all 4 cylinders. I'm recommending we do a overhaul with new cylinder jugs, pistons, and bearings.
This is on a Deutz-Allis 7085 2wd from early 80s. Does anyone know if you can get away with dropping the oil pan without splitting the tractor? Looks like 4 out of 6 bolts for the front axle connect to the oil pan. Can I sneak it out without pulling the whole front axle by just leaving the other 2 bolts in?
Unverferth 432 (A64119)
Unverferth 432...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63688)
Magnolia Trailer...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2015 FREIGHTLINER CASCADIA 125 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A59911)
2015 FREIGHTLINER...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
