Deutz 6006
/ Deutz 6006 #1
rmccluskey
Deutz 6006
I am not able to raise the 3 point hitch on my Deutz 6006. I changed the filter and cleaned the screen that is located in the reservoir. I'm just not sure what my next step is. Any help is appreciated.
/ Deutz 6006 #2
Not familiar with that tractor TractorData.com Deutz D 6006 tractor information but did you check your linkage going to rear or does it have a valve that could possibly be all way left to open free position. ?
Boone
/ Deutz 6006 #3
Does it have a FEL? Is it working. Did everything work before. Have you checked hyd pressure?
/ Deutz 6006
It does have a front end loader and it is working. Before the 3 point quit working altogether it would lift all the way up when the lever was in the down position. With an implement attached it would quickly jerk up a little ways (1 - 2 inches) and fall back down. It would do this every couple seconds.
/ Deutz 6006 #5
Your piston seals in the 3pt are probably worn. If you connected a gage in the system, you would probably see the pressure rise and fall.
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
17394SFL (A61568)
17394SFL (A61568)
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2014 Ford F-150...
