Deutz 6006
/ Deutz 6006 #1
rmccluskey
Deutz 6006
I am not able to raise the 3 point hitch on my Deutz 6006. I changed the filter and cleaned the screen that is located in the reservoir. I'm just not sure what my next step is. Any help is appreciated.
/ Deutz 6006 #2
Not familiar with that tractor TractorData.com Deutz D 6006 tractor information but did you check your linkage going to rear or does it have a valve that could possibly be all way left to open free position. ?
Boone
/ Deutz 6006 #3
Does it have a FEL? Is it working. Did everything work before. Have you checked hyd pressure?
/ Deutz 6006
It does have a front end loader and it is working. Before the 3 point quit working altogether it would lift all the way up when the lever was in the down position. With an implement attached it would quickly jerk up a little ways (1 - 2 inches) and fall back down. It would do this every couple seconds.
/ Deutz 6006 #5
Your piston seals in the 3pt are probably worn. If you connected a gage in the system, you would probably see the pressure rise and fall.
2014 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWDGXEL206125 (A61165)
2014 Jeep Wrangler...
2016 16ft. C and S Lawhon 2.5 Ton Pipe Top T/A Utility Trailer (A60352)
2016 16ft. C and S...
2019 FREIGHTLINER 126 SLEEPER TRUCK TRACTOR (A59909)
2019 FREIGHTLINER...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
2016 Dodge Grand Caravan SE Plus (A61569)
2016 Dodge Grand...
