Deutz 5220 will not start
/ Deutz 5220 will not start #1
Oldmanjeffers
88 deutz 5220
Hello all, I ran my 5220 out of fuel and now after bleeding the air out of the system it will not fire up. I pulled an injection line and there is very little pressure coming from the injection pump. Could I have damaged the injection pump by running it out? The thing has been hard to start for a few years now but it did start Everytime with a little cranking.
While trying to diagnose the issue I found one of the injection line fittings coming off of the pump to be very loose, actually very surprised there wasn't fuel coming out of it... Could this be an issue? Cause of failure?
All air is removed from the system. I grasp the importance of this and am getting just fuel, no air to the pump. From the pump forward I get very little pressure. I do not have a pressure gauge but with a line off there is no fountain, squirt or, for lack of better words, impressive amount of fuel pressure coming from the injection pump.
Any help or meaningful advice is much appreciated. Thanks!
/ Deutz 5220 will not start #2
Do you have an owner's manual? The bleeding instructions should be in there.
Generally, first you bleed the fuel filter(s), then the pump, then the injectors. Do you have a lift pump in the fuel delivery circuit? If you do, is it working? Make sure your battery is well charged before you bleed the injectors. When is the last time you changed the fuel filter? Is your air filter clean. It takes fuel and air to make a fire in the cylinder.
No owners manual, As per my post all air is out of the system. I'm getting all fuel, no air to the pump, when I crack the injection lines I get all fuel ( what little there is ) no air to the injectors. To get at the injection lines one needs to take off the intake hose so it's getting all the clean fresh air it could want.
I've never seen an injection pump put out such a miniscule amount of fuel and pressure but this is also the first MS142 I've worked on.
This is a all mechanical fuel system, so no lift pump.
Thanks for your advice.
/ Deutz 5220 will not start #4
The only time you'll get much pressure from your pump is when there is back pressure against it. You can check pressure with a gauge. It's a low volume high pressure pump.
Thank you, I've searched the net for what pressure this pump is supposed to be creating but have come up with nothing. Buying a service manual is inevitable but by chance does anyone know what that should be?
Thank you for your reply
BTW nice bike!
/ Deutz 5220 will not start #7
Re-torque the loose dv holder on the pump to 30 -35 ftlbs..check them all..
R u POSITIVE about the supply pump.?? Loosen the inlet banjo bolt at the pump inlet and crank the engine..
If it shoots out, u have a lift/supply pump..
I did check the other DV holders, everything is tight. I can see the fuel line running from the tank to the filter to the pump, I can see into the fuel tank so unless the lift pump is a quantum, micro, wireless inline retrofit done without my knowledge in the last 25 years it does not have a lift pump.o_O
Thanks for the advice! I'll be back at it today.
/ Deutz 5220 will not start #9
Can u post a pic of the inj pump.?? If it’s to difficult to post on the forum, u can send it to my email..
My screen name @aol.com
/ Deutz 5220 will not start #10
Have you seen this site?
This is the operator's manual for the Deutz Allis 5220 and 5230 tractor.
This manual contains information on operating, adjusting, maintaining and troubleshooting for your Deutz Allis tractor.
$19.99
think you can get a free one here
Tech spec's
willy
/ Deutz 5220 will not start #11
If you remove the filter outlet line, do you get a gush of fuel-like a cow peein' on a flat rock? You should.
/ Deutz 5220 will not start #12
The top of the mechanical fuel pump mounted on the side of the engine block near the injection pump is a filter screen.
That filter screen is the number one cause for fuel starvation issues on a deutz engine.
Remove that bolt on the top of the mechanical fuel pump and the top will come off.
Those air cooled deutz engines are pretty bullet proof and very rarely do they have injection pump issues.
Another thing to check is the banjo fittings. They can clog with gunk internally. It's usually the intake side of the filter or intake to the mechanical fuel pump.
With running the tractor out of fuel, you probably just sucked some gunk into the fuel system.
/ Deutz 5220 will not start #15
The 5220 is Japanese. It has nothing Deutz or air cooled about it. Are you aware of that?
/ Deutz 5220 will not start #16
Exactly. It was made by Hinomoto and it has a Toyosha water cooled engine.
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
2012 TROXELL 200BBL CRUDE TANKER (A65643)
2012 TROXELL...
Hatz 0.5L Diesel Engine (A64127)
Hatz 0.5L Diesel...
