Deutz 1011 compression test
/ Deutz 1011 compression test #1
Cord
Richfield, Wi
Resident Architect
I have a Deutz 1011f in my skidsteer and it's been getting harder and harder to start. Second glow plug, pan heater and even ether no longer gets it to start. Usually the engine runs good and has full power, however on occasion it develops a miss that lasts for roughly 30 seconds. After a while the miss clears up and it's running fine again. I tried replacing the fuel pump last fall and I really havn't put enough hours on to see if that cured the miss. Regardless, it still won't start. Now I'm to the point where I want to check the compression ratio. The problem is that I can't find an adapter that fits the injectors. Anybody know what size threads the injectors have?
T/A Drop Deck Equipment Tailer (A64556)
T/A Drop Deck...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
Melroe 5525 Skidloader Backhoe Attachment (A65640)
Melroe 5525...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2018 Freightliner Cascadia 125 Truck T/A Sleeper Cab Truck Tractor (A64194)
2018 Freightliner...
Mayrath 10 x 63 Portable Swing-away Auger (A66408)
Mayrath 10 x 63...
