Dessicant on fuel tank vent
   / Dessicant on fuel tank vent #1
BeezFun
IL
Kubota B2710
I'm thinking of installing this dessicant vent breather on my diesel tank. Does anyone have experience with using these or a good brand?
   / Dessicant on fuel tank vent #2
The fuel tank on my M6040 has a long rubber hose on the vent. Goes up high into the tractor framework. Terminates with a small filter. Keeps crud from being sucked back into the tank. Eleven years now - not even the tiniest bit of dust on or in this filter.
Nice idea!
Wonder how long it lasts?
Probably depends on how often the tank is used. I'm using this on a 50gal storage tank that only gets used every few weeks, so I'm hoping it will last a long time. Keeping the tank full also probably helps so it doesn't have to scrub the air that's in the tank as the temperature changes.
   / Dessicant on fuel tank vent #5
For a 50 gallon tank kept mostly full,and infrequent use,your reasoning seems spot on!
Good Luck!
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2016 FREIGHTLINER...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53473)
LIKE NEW 2023...
1984 Utility 44 ft. Reefer Trailer (A53117)
1984 Utility 44...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
Charlotte County (A50323)
Charlotte County...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
