Describe the Ultimate BX
/ Describe the Ultimate BX
Well, as the O.P., I got the model number wrong. I thought they'd follow the BX2660 with pretty much the same tractor coupled to a backhoe. I thought they'd use the 3200 rpm version of the D1005 block and call it a BX26 based on the hp. I didn't think they'd transition from BX24 to a BX25 with such minor changes. I was hoping they'd implement more of the ideas that had been mentioned in this thread.
/ Describe the Ultimate BX #42
There is the simple issue of cost. If you implemented many of the things that are mentioned here you'd be right up to the price of a B2320.
/ Describe the Ultimate BX #43
Do any of the SCUT have reversible rims? I wouldn't think it would be to costly and add much stability to those with hillside property.
/ Describe the Ultimate BX #45
As an engineer AND marketing person, I have to ask everyone who has responded to this post:
How much is each feature worth in $$ to you? Just because competitors offer a feature doesn't automatically make it free for Kubota to add.
I went through a few of the lists on here, and can easily see a BX tractor running $3000-7000 more base price to accomodate the feature lists. Features cost a lot more than you'd expect.
Great example: Reversible rims. Sounds cheap, right? Well, lets not forget a few other issues:
1. Need to qualify the axles to meet life requirements in the worse case condition (BX25, rims wide, fully ballasted, etc...). May need larger rear axle casting to accomodate the new bearings for higher moment loads.
2. Gonna need to redesign the mower decks for clearance on wider tires.
3. May need a thicker rim to handle the increased stresses.
4. Since the crown of the tire is now closer to the edge of the fender, we need to redesign the fender, gosh darn it.
5. Oh, and now all the owners of existing BX's machines are buying the reversible rims, and screaming for warranty because their axles break, the tires rub the mower deck, and when they put chains on the tires the chains rub the fenders.
Welcome to the world of engineers.... Sorry if this sounds like a rant, but I've been through this too many times. Kubota makes pretty darn good machines. not 100% of the features we'd like, but the 80/20 rule seems to equal success for Kubota!
AndyinIowa
/ Describe the Ultimate BX #46
Reversible Rims...
Since Kubota sells spacers to widen the stance, it would seem they are comfortable with the axles, housings and fender placement to accommodate...
I think Tom H, the original poster, has actually provided a service to the BX engineering team by posing this question to thousands of loyal BX owners/operators...
Business today is becoming even more competitive and manufacturers that build products with the consumer in mind will always have an edge...
/ Describe the Ultimate BX #48
Kubota does not sell spacers, someone else is building them.
Neil... Is it only for the BX that Kubota Spacers are not available?
I found this on the B series:
"Kubota makes a spacer kit that add 1.5" to each side. The kit used to be priced at @ $242. The part number is B8785. This kit fits B2710, B2910, B7800, B2630, B3030."
The points that Andy and Neil make about so many extras driving up price are valid. As the OP in this thread, I knew there was no way Kubota was going to rush to study it and incorporate every idea we tossed into the arena. Still, Andy, there is no reason we can't all have fun discussing things we'd enjoy seeing on a BX.
Some of the suggestions in this thread would require modification of the tractor itself, but a number of the things on our list are things that can be options without changing the design of the tractor. For a company as big as Kubota, many of these things would not be cost effective at the level of demand. Luckily, though, we do have little aftermarket businesses whose level of production can match the level of demand. There are aftermarket wheel spacers available for the BX. Seems like it maybe Larry at MowerAxle who makes these; I know I've seen photos of BX wheel spacers on TBN. Some of the other little aftermarket products include Larry's mower axle wheel stands for MMMs, Richard's skid plates, ripper, and thumb at Bro-tek, Wallenstein's thumb, American Solutions' grapple and tilt meter, top 'n tilt offered by at least 3 firms, canopies, ROPS mounted lighting, Tiny Tach, bolt and weld on bucket hooks, and many others that don't come to mind at this moment. Andy, one benefit of a thread like this one is that it can give new ideas to the small entepreneurs about new products that might succeed in the small-niche aftermarket area. You're an engineer, come on and join us in having some fun. Which, of all the ideas in this thread, do you think could be an entepreneurial success in a small demand aftermarket?
/ Describe the Ultimate BX #51
And i have one more to add. I would like for the BX BH relief valve to be designed to where there is no potential damage when using the MMM with BH and FEL all attached. I dont know of anyone who has actually had a problem with the relief valve but the manual says MMM use while BH attached is a no no. Fix it to where it is not a concern though.
/ Describe the Ultimate BX #52
Kevin,
As a "fix" install the BH lock pins and unhook the hoses (re-attach the power beyond on the tractor). Doesn't address the situation at the "Ultimate BX" manufacturing point but prevents damage to the valve if you really want to mow with the BH installed.
/ Describe the Ultimate BX #53
Sorry, my regular forums have all been hard on engineers and OEM's lately. Seems like its an endless rant on 'crappy engineers who can't get it right' and 'why can't the OEM add this or that because everyone ELSE offers it'.
I enjoy throwing out wish lists, but its also nice when posters acknowledge that there are a LOT of constraints placed against the people creating and building these awesome machines.
My BIG wish is that Kubota would have a strong aftermarket design group that comes up with all the tools and add-ons that we discuss on the forums.
Consider Harley Davidson, who offers THOUSANDS of little accessories and options. It would be great if we have 12 different belly pans, 18 lighting options, etc... to choose from when we buy a new tractor.
My dream conversation with the Kubota AfterMarket Artist:
"Well - Andy, how would you like to dress up your BX2350?"
"That's a good question, Zeke! I'd like to have it delivered with the chrome wheel package, Calcium filled rear tires, foam filled fronts.
I'd like the twin halogen rear light kit, with optional locking brush covers. I'd like the Armadillo skid plate package with remote filter adapter and the tough service hydraulic cooler package.
I'd also like the Rock-Off quick attach front loader bucket. Throw in the grapple bucket and front box blade.
Oh! don't forget the poly-mod conforming toolbox, tubular brush cage for the front hood, and the NO-PAIN CHAIN hook package."
"Excellent choices, if I may say so sir!"
Zeke quickly punches up the order on his smartphone.
"Now Andy, since you have purchased these options, you qualify for the platinum service package, which includes 3 years of complete scheduled maintenance, including a spring and fall well-tractor checkup. Would you like to schedule those now, or we can email you a form to schedule your appointments!"
"Thanks Zeke, email me the form."
"Anything else?"
"Oh yeah, I also want the neoprene seat and steering wheel upgrades"
"No problem."
Now THAT is a wish I'd love to see come true!
IowaAndy
/ Describe the Ultimate BX #57
Ole Larry has been bumping old threads for yrs, course he's not the only one around these parts :D
Dave
/ Describe the Ultimate BX #58
thats a great way to put it, wish it could really happen that way for the money we are spending!!!!!!!!!!!!!!!!!!!!
