Describe the Ultimate BX
/ Describe the Ultimate BX #21
One thing I really wish was available on the BX was a quick attach bucket system on the front loader like the John Deere (probably means dual cylinders) - and quick disconnect bucket on the backhoe. I have wished for these things a number of times on my BX23. A lot of the other things I might wish for have been fixed on the BX24 - too bad I cant afford a new tractor at the moment.
/ Describe the Ultimate BX #22
MessickFarmEqu said:
Frankly, I think the 26hp BX is stupid. There is no need for that kinda power in a subcompact. Its all because of the HP race between companies and the customers focus on that rather meaningless number.
Ditto
/ Describe the Ultimate BX #23
Lower the stupid ROPS 3"... I learned my lesson destroying my garage trim, then my cousin did the same thing to his when borrowing it!
Also, not a fan of the dual pedal setup for forward/reverse... it is difficult to smoothly transition a lot of the time.
Else, great tractor and wouldn't change much. Had it just over a year now and it has been just about perfect for my needs.
Karl
/ Describe the Ultimate BX #24
kfosburg said:
...not a fan of the dual pedal setup for forward/reverse...
Funny. I had the choice when I bought my tractor. That (the split treadle instead of single treadle) along with the metal fenders (vs. plastic) was one of the reasons I went with the 2230 instead of the 2350.
Lost out on the lower profile front tires (not a biggie), the higher 3PH (actually, that would have been nice), the 1 HP (woop-tee-doo...has too much power already), and the curved FEL booms (probably better, but I don't know).
Won on lack of broken fenders (metal everything), comfy treadle, and a nod from the wife by owning a tractor-looking-tractor. She thought the 2350 looked like a race car. I actually like that my FEL lever LEAVES with the FEL and doesn't stick me with that huge wand ALL the time.
And saving over $2,000 at the time didn't hurt, either.
Sometimes, looking back is the best way to look forward. Put on the "Ultimate BX" list the following: Metal hood/fenders and a single treadle just like on the 1830/2230/23. And a choice of quick disconnects to have the FEL wand stay with the tractor or leave with the FEL.
/ Describe the Ultimate BX #25
I want a navigation system, air conditioning, an mp3 player, a tilt wheel, an overdrive gear, a center console, a heated seat, a side car, and some side mirrors. I'm going to sell my cars and trucks and just drive my BX everywhere since a gallon of fuel lasts about 3 hours.
/ Describe the Ultimate BX #26
Mr. RayCo, I think you're just getting silly. Why do you need an MP3 player? IPod connectivity is much more useful. An MP3 CD only holds 150 or so songs. And you need to ask for a third gear range...SH (Super High). Better to get to PA Turnpike speeds.
NOW we're talking.
/ Describe the Ultimate BX #27
Does the annual Kubota dealer's meeting begin tomorrow. If it does, then we should know what the new B7610 and B7800 and new BX replacements are tomorrow?
thanks mark
/ Describe the Ultimate BX #28
Here's what I'd like to see...
1. More lifting capacity on the FEL so one can put a Millionzi grapple on it. This means factory QA also.
2. Shorter/foldable ROPS. Then they can take the metal savings and and put it towards getting rid of the plastic and going metal.
3. Move the joystick from the dash to the seat side. I hate the current setup because it interfers with getting on and off from the right side.
4. Factory skid plates. If nothing else, make it a low cost option. This should be a no brainer since the cost to have it as standard equipment probably would cost Kubota less then $10.
5. Different dash layout with a analog tach and temp guage.
There's lots of other things that can be done too, but if I had to pick one thing I'd like more to see more FEL lift capacity. Man do I want a Millonzi 48" grapple!
/ Describe the Ultimate BX #29
Sounds like what you want is a larger B series tractor. You do realize that every one of your concerns could be alleviated by an upgrade ;)
/ Describe the Ultimate BX #30
I've got the B series brochure and I didn't see much different in the smaller B tractors. The FEL capacity isn't much better and the joy stick is still in the wrong place. Yes, I like the smaller ROPS and dash, but those are minor compared to the FEL capacity and I don't want the larger B tractors because they're just to big.
Here's the specs:
B7610
Tractor weight: 1367 lbs
FEL capacity (LA352 19.7" fwd): 670lbs.
BX24
Tractor weight: 1542 lbs
FEL capacity (LA240 19.7" fwd): 518lbs.
Here's what I don't get.... I don't know why someone would get a B7x10 series other then for the PTO lift capacity and slightly bigger size because the BX looks better in most every other category, even price.
/ Describe the Ultimate BX #31
I was thinking bigger yet... a B2630/3030 would give you the option of using the remote FEL valve made for the cab, relocating the joystick on the fender (that valve may work on smaller B's, I really don't know). If you ask me though, the joystick is in the way even more on the fender than when it is beside the dash. Also the bigger the tractor, the less "in the way" the dash joystick is anyway b/c there's generally more room for operator platform. The few times I do exit the right side of the tractor the joystick is never in the way but I gotta watch out for the various fender-mounted "coat hooks".
Your points about the B7610 are valid, and I suppose that could be why it's getting a new replacement.
1. More lifting capacity on the FEL so one can put a Millionzi grapple on it. This means factory QA also........Man do I want a Millonzi 48" grapple!
CrabJoe,
Did you know that American Solutions has a grapple designed specifically for the BX?
American Solutions LLC
/ Describe the Ultimate BX #33
I thought of another feature:A seat that rotates and locks only part way around ,[like on a new holland] so it aids when running rear attachments while driving.Im trying to figure how to modify mine,so i can run a 60 inch rear blower.
ALAN
/ Describe the Ultimate BX #34
A few things I've thought of...
Reversible wheels for a wider stance on Hills would be a nice feature.
Enough Hydraulic GPM to run some smaller Hydraulic Attachments
More Powerful Backhoe "Curl"... I run up against the pressure relief more than I like.
Slightly lower ROP or an optional reduced size to fit 7' garage doors would be nice.
Hydraulic Thumb???
/ Describe the Ultimate BX #35
Frankly, I think the 26hp BX is stupid. There is no need for that kinda power in a subcompact. .
While I would concede that I have limited experience so far, I have noticed no task that requires more horsepower at this point.
The only things I would suggest or
1. Deal with the plastic Hydro fan deficiency. Protect it.
2. Increase the 3 pt hitch lift range to achieve a higher lift.
3. Increase hydrolic GPM to increase range of implements that can be used.
And on the wish list not related to the tractor itself....
Someone develop a sub $10K mini hay bailer that the BX can handle.
/ Describe the Ultimate BX #36
I would like an analog Tach with a seperate hour meter, foldable ROPS, and reversable rims.
/ Describe the Ultimate BX #37
The whole dash should be different. The BX24 dash is embarrassing, really.
I'd like to see a cupholder that has a smaller drainage opening, or perhaps one that is screened instead of just open so that things other than cups can be tossed in there without fear of losing them out the bottom.
I'd like a horn. I'm not really sure why though. :)
How about a seat that is anything other than black? Man, the thing sits in the sun for 60 seconds, and my flesh melts to it when I sit down. It's really freaking awful!
</div>
/ Describe the Ultimate BX #38
</div>[/QUOTE]
I agree with you on the seat getting hot the John Deere I had had a yellow seat it didn't seem to get all that hot. I have thought about covering it with a white T-shirt. I wonder what other color Kubota could use for a seat orange?
/ Describe the Ultimate BX #39
I'm quite happy with my BX1500. It even has the treadle pedal I prefer.
What I would think could be done is to do a replacement of those horrible turnbuckles with solid hitch adjusters.
I made the modification a little while back, and don't know why it took me so long to get around to. Best thing I ever did.
I don't even know that they haven't done this, but I haven't seen mention of it.
-BXRICK
/ Describe the Ultimate BX #40
I'd actually like to see them build a BX model that is SMALLER. yep, I said it....bigger is not better on my property. Smaller.....narrower, shorter, and lighter then the BX1500 was. Basically I want all the features I love, like 4WD, diesel, Hydro, power steering, 3-pt, loader, etc in a package that is more like a midsized garden tractor.
I want a ROPS that folds so when your not using the FEL and just mowing on flat ground, you can fold it up to dodge the tree limbs.
I'd like a quick attach bucket so I can swap on a snow plow or something else.
I want two pedals side by side like my JD lawn tractor for forward and reverse.
All metal!
Easy adjust 3-pt arms so I can throw those turnbuckles in the trash.
Remote hydro for the rear standard.
I want to be able to add the Kubota BH whenever I want (not a woods), and not have to buy it upfront as a package.
I'd like a full floating mower deck (like a simplicity) with the striping roller and swivel wheels on each corner for easy removal.
how about a turbo?????
When can I pick mine up???
