Dented Hood Help!
/ Dented Hood Help! #21
This is new. I have seen the loaders not fastened in right and fall out before and leave a crease across the hoods.
/ Dented Hood Help! #22
I have never taken the loader off mine, but I have lifted the front wheels dozens of times and not dented the hood on the way back down. I really wonder if it is possible that the hood or the side panels were not firmly latched in place and moved, causing the hood to buckle. I can't imagine the frame being broken and causing the flex, you'd notice other signs of trouble in other parts of the tractor if the frame was bent.
/ Dented Hood Help! #23
Viper....Am I mistaken or dosen't the location of the dents look as if they were caused by the hood slamming hard against the front grill guard when opened????????????? /forums/images/graemlins/confused.gif
/ Dented Hood Help! #24
Those dents could not have anything to do with rasing the front wheels off the ground, that is a normal thing to do and we all do it all the time. The dents are caused by either 1) attempting to remove the loader and forgetting to put the kickstands down, 2) the hood some how not being properly adjusted and slamming down such that the sudden stop creased the hood---not likely, 3) not having reinstalled
the pins in the loader arms and the loader falling out of the arms.
Once I forgot to put the kickstands down and put the loader lever to down--as to lift the wheels which when the pins removed lifts the loader frame out of the arms. The loader cross brace nearly hit my hood but with brute force and quickness on my part I caught it--yelled bloody murder for my wife who came to me and my tractors rescue. If it had hit I think the hood would have dents similar to those though they do seem a bit forward I where I might expect them.
Another possibility--they were already there when you bought it and your dealer knew that was the case and therefore does not want to hear from you---goodluck. Seems that those would be easy to fix but if that is damage from improper use then it is your problem, if it was damage from the dealer--he owes you a new hood. J
/ Dented Hood Help! #25
viper
I have had my 2910 for over 3 years with no dents like you show in the pictures. I went out and looked at my tractor to see how that could happen.
It does look like the cross bar made the dents. Have you looked at the bottom of the cross bar to see if there are any scratches in the paint.
Checked the position of the dents in your hood to the length of the hoses on my FEL, The dents are just beyond what my hoses would allow the loader to be removed with the hoses on. I did break off a hydraulic fitting while installing the FEL about the second time I tried it. I was backing away from FEL and did not watch how far I had moved back. Cross bar hit one of the fittings and broke it off. /forums/images/graemlins/blush.gif
Did you have your FEL stored an on hard surface? If you had it stored on soft ground the FEL could have dropped down and made the bar come close to hood to dent the hood.
If the bucket was rolled back during its removal the bar could also come very close to the hood.
The one thing I worry about when using the FEL is raising it all the way up and some thing falling out of the bucket and falling on the hood. So far all the things that have fallen have missed the hood. /forums/images/graemlins/smirk.gif
My 2910 does have some scratches on it and at times a lot of dirt. No dents yet. /forums/images/graemlins/tongue.gif I would be just as upset as you if a dent showed up that I had no idea where it came from. /forums/images/graemlins/frown.gif
/ Dented Hood Help! #26
</font><font color="blue" class="small">( Have you looked at the bottom of the cross bar to see if there are any scratches in the paint.
)</font>
I think Ron is really on to something here. Here is what I think happened.
1) Hood was damaged by dealer while installing loader
2) He did'nt notice or kept quiet about it
3) You (viper) were'nt looking for dents, so you did'nt notice them.
4) Your loader was used to lift the tractor off the ground for the first time and this caused the components to settle in and adjust. (many folks with a NewHolland know how their brackets move) This adjustment made the noise.
5) When you heard the noise, you looked for the source and found the dents.
This is just a theory, but I would check for signs of paint damage or scrapes on the underside of that cross bar.
/ Dented Hood Help! #27
</font><font color="blue" class="small">( Here is what I think happened.
This is just a theory, but I would check for signs of paint damage or scrapes on the underside of that cross bar. )</font>
I don't think that viper is so senile or poor sighted that he wouldn't notice this long before 28 hours. If it happened the way he has said, then the external cause has yet to be found, but it will be explained how at some time in the future..... Just like the crop circles!!!!!!! /forums/images/graemlins/shocked.gif
/ Dented Hood Help! #28
I don't think viper is senile or poor sighted. But, I believe he could have not noticed these dents if he was not looking for them. Recently, I noticed that the windshield molding seal was loose on my van. One of my co-workers said that he had noticed it one day this past summer. The point is, I was'nt looking for a problem so I did'nt see one.
/ Dented Hood Help! #29
I don't own a Kubota, but from one of the angles, it looks like the hood is slightly rounded. If that is the case, could the cross bar have made the dents on the sides of the hood without denting the top of the hood? The top looks unharmed.
As far as the dealer doing it--nothing would surprise me, however that's a part of the tractor that you look at all the time when doing loader work. Those dents are not impossible to overlook, but it seems unlikely to me.
Keep us posted Viper--it's an interesting issue and I agree with not replacing/fixing until you are sure of the cause.
Good Luck
Bob
/ Dented Hood Help! #30
viper,
You stated that you had the loader off of the tractor. When you park the tractor do you park in under the loader frame. The photos look like the hood was opened against the loader cross member. If you were parked under the loader, but not pulled all the way under, than the hood will hit about were the dents are. Did you try to lift the hood to check the oil or anything else when parked this way? (if you were parked this way)
/ Dented Hood Help! #31
Bob
When I checked my hood I pushed down on the center. I was able to make the raised area lay flat with very little pressure. /forums/images/graemlins/blush.gif The metal is thin and there is no support under that area. /forums/images/graemlins/tongue.gif
/ Dented Hood Help! #32
Something similar to this happened to a friend of mine a couple of years ago. His son pushed on the hood in the center to slam it shut after some maintenance and there was a filter wrench lying near the latch. The hood buckled across the center but I think the crease went all the way across the hood (it had a dent at each end if the crease like yours). He spent a lot of hours trying to straighten it out but he could never get it to fit properly. He eventually bought a new hood/forums/images/graemlins/mad.gif.
John
/ Dented Hood Help! #33
Ron,
Thanks for the clarification--if there isn't much support and a lot of give, I can see how it could happen. I was just having a tough time envisioning the side dents without major damage to the top portion.
Bob
/ Dented Hood Help!
Thanks for all the replys, here is another pic. The tractor wasn't damaged when I bought it, I have waxed it several times and sure I would have noticed it before now. I've hit nothing nor has the hood hit anything. It's garage kept so I know now one could have done something to it without my knowledge. If you look at the attachment you can see the hood is bowed in the middle and doesn't line up with the other panels and a crease is across the hood.
/ Dented Hood Help!
another pic
/ Dented Hood Help!
1 more pic
/ Dented Hood Help! #38
Hi Viper,
I just went out and looked at my B2910, and the hood is supposed to bow up in the middle like yours does. Also your hood and side panels fit a lot better than mine do, and my hood has never been damaged. Like others have suggested, I think the crossbar caused your dents. Possibly when the loader was being removed or reattached the crossbar made contact with the hood when the loader valve was moved the wrong way or the loader slipped off the pins and dropped. If your frame is not cracked or broken there is no way that having the front end off the ground could cause those dents. If it could, mine would look like it had been run over by a bulldozer as many times as I have had the front off the ground. /forums/images/graemlins/confused.gif
/ Dented Hood Help! #39
The hood is supposed to bow up in the middle when seen from the side. My 2410 has a bow in the middle and the top is rounded as well. It is exactly the way it is intended to be. Also, your panels seem to line up about as good as mine do--it is not a Lexus, it is a tractor. Your hood was dented by the cross bar of the loader. Lifting the wheels of the ground could not cause this, assuming the loader is pinned, most likely you dropped the loader on to the hood while attaching or detaching and did not notice somehow. Your loader does have kick stands does it not? You are supposed to put those down before removing the loader.
I sometimes store my loader with the tractor parked under it to save space. If I open the hood it will spring into the loader cross bar. This also could have caused the dents. In any case it was operator error.
Good luck. J
/ Dented Hood Help! #40
Viper, was the tractor in for service at the dealer anytime after you did your waxing? Mine was damaged at the dealer, and he called me to tell me about it. I wouldn't have noticed it immediately if I hadn't been looking for it. (luckily he's an honest guy). As stated earlier, mine was dented like that when the tech didn't put down the support arms while taking off the loader. in terms of dent repair I'd take a close look at the paint in the dents. On mine it was "cracked" and started to flake off "in" the dent within a month.
Regards,
Dave
FIRD MIXER TRUCK (INOPERABLE) (A67714)
FIRD MIXER TRUCK...
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
2018 BOBCAT E26 (A68134)
2018 BOBCAT E26...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
2023 WALLACE-THE ROOSTER ROOT PICKER PINTLE HITCH (A65057)
2023 WALLACE-THE...
2013 STEPHENS CRUDE PUP TRAILER (A67714)
2013 STEPHENS...
