Delta drill press ACME nut
   / Delta drill press ACME nut
It’s definitely an acne thread.
   / Delta drill press ACME nut #13
FWIW: @90cummins if you can knurl it, ACME 3/4-10 round internally threaded is available from the usual folks.
McMaster, Roton, etc. Bronze and steel.
All the best,
Peter
I’m aware that I can work around it, just didn’t think it would be a big deal!
Parts for this old iron is pricey😬
Thank you for the advice 👍
   / Delta drill press ACME nut #15
Welcome to the club!
   / Delta drill press ACME nut #16
3/4-10 isnt a common acme thread.
If you can indeed get the direct replacement for $35.....probably well spent.
   / Delta drill press ACME nut #17
If that is your photo in the OP, then it sure doesn't look like Acme. 3/4-10 is the stand UNC coarse thread in that size. I'd at least try a cheap stock nut from the farm store first to verify...
I found a 3/4-10 bolt & nut in my catch all pile and put it up to the acme the thread and it is a perfect match at 10 threads per inch and NO the nut does not turn on the acme rod.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2018 FREIGHTLINER...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
378577 (A51573)
378577 (A51573)
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646721 (A51572)
2013 Dodge Charger...
