Delighted with Piranha bar
/ Delighted with Piranha bar #1
Raised on a Deere
Lawrenceburg Ky
Ford Dexta, Branson 6530c Yanmar Lx490 Power reverser
Install was easier than expected. Drilled the two holes with standard Dewalt bimetel holesaw, under $10 bucks. Used some blocks to pry against to control ressure to drill.Had wife keep drip of oil on bit, go slow ant hole completed in very short time. I never knew those hole saws were so good in this type of steel.
The piranha bar transforms the bucket. I removed large stumps, cleared brush, removed two foot of clay from a barn site. I doubt I ever remove the bar. It takes abuse. I was concerned that it might get messed up if I curled the bucket under corner of a rock or something. It remaind unscathed and i just poke it under whatever i want to and curl. Learned to push under stump and keep jabbing and in a few jabs it has burried the bucket under the stump. Do this on each side and in front and then raise bucket to top of stump and it just goes over. I was amazed after all the stories on stump removal.
If you think you need some enhancement for your bucket this will delight you.
/ Delighted with Piranha bar #2
I love mine too. I only remove it in winter to use my bucket for clearing snow (in conjunction with a rear blade) so I don't mess up my driveway. It only takes a couple minutes to take off and put back on.
/ Delighted with Piranha bar #3
I really like mine too. It was money well spent.
/ Delighted with Piranha bar #4
anyone have a pic of one on the kubota 72 inch doublewall bucket (bolt on edge?)
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2017 Ford Fusion Hybrid Sedan (A66738)
2017 Ford Fusion...
CAT D9H 4BBL Multishank Ripper (A68134)
CAT D9H 4BBL...
1996 INTERNATIONAL (INOPERABLE) 4700 (A67714)
1996 INTERNATIONAL...
2018 GMC Sierra 2500HD 4x4 Pickup Truck (A66736)
2018 GMC Sierra...
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
