Raised on a Deere
Gold Member
- Joined
- Aug 7, 2013
- Messages
- 314
- Location
- Lawrenceburg Ky
- Tractor
- Ford Dexta, Branson 6530c Yanmar Lx490 Power reverser
Install was easier than expected. Drilled the two holes with standard Dewalt bimetel holesaw, under $10 bucks. Used some blocks to pry against to control ressure to drill.Had wife keep drip of oil on bit, go slow ant hole completed in very short time. I never knew those hole saws were so good in this type of steel.
The piranha bar transforms the bucket. I removed large stumps, cleared brush, removed two foot of clay from a barn site. I doubt I ever remove the bar. It takes abuse. I was concerned that it might get messed up if I curled the bucket under corner of a rock or something. It remaind unscathed and i just poke it under whatever i want to and curl. Learned to push under stump and keep jabbing and in a few jabs it has burried the bucket under the stump. Do this on each side and in front and then raise bucket to top of stump and it just goes over. I was amazed after all the stories on stump removal.
If you think you need some enhancement for your bucket this will delight you.
