Defective Innertube
/ Defective Innertube #1
New Holland TN75
After the tire shop replaced the inner tube in my 16.9-30 tire that I carried in to them on a trailer, they filled it with tap water and one gallon of red antifreeze. Unfortunately, I couldn’t get any help at home to unload the tire, so I drained the fluid by removing the outer half of the valve stem and placed a 1/4” tube inside and let the ballast siphone overnight. The next morning, the tire wouldn’t hold air because of a major leak at the valve stem. What would cause this in a brand new inner tube?
/ Defective Innertube #3
Don't the liquid valve stems have an o-ring the seals them? Might the o-ring be damaged or missing?
/ Defective Innertube #4
You mean the internal to the valve stem itself? The core of the valve itself sometimes needs to be tightened. We usually unscrew them to put liquids in or out, right? If it is not screwed in tight enough to seal the valve body in, it can leak around that? You can also put in a new valve, if damaged
decent details here >
It’s leaking from the base underneath the nut, as if the vulcanization failed from where the outside of the metal part is vulcanized to the rubber part.
Personally, I think the inner tube was defective, but no way to prove it since they cut it in half to take it out before charging me to install another one. Tube is Gateway from Korea.
2026 SDLANCH SDLC1220 High-End Carport (A64194)
2026 SDLANCH...
6' STACKING RAKE (A64276)
6' STACKING RAKE...
2018 Ford Escape SE SUV (A64557)
2018 Ford Escape...
JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A64553)
JMR 78in Dual...
2011 18ft. Maxey Flatbed Utility Trailer (A64194)
2011 18ft. Maxey...
2000 Chevrolet Astro Passenger Van (A64194)
2000 Chevrolet...
