Defective Innertube
/ Defective Innertube #1
New Holland TN75
After the tire shop replaced the inner tube in my 16.9-30 tire that I carried in to them on a trailer, they filled it with tap water and one gallon of red antifreeze. Unfortunately, I couldn’t get any help at home to unload the tire, so I drained the fluid by removing the outer half of the valve stem and placed a 1/4” tube inside and let the ballast siphone overnight. The next morning, the tire wouldn’t hold air because of a major leak at the valve stem. What would cause this in a brand new inner tube?
/ Defective Innertube #3
Don't the liquid valve stems have an o-ring the seals them? Might the o-ring be damaged or missing?
/ Defective Innertube #4
You mean the internal to the valve stem itself? The core of the valve itself sometimes needs to be tightened. We usually unscrew them to put liquids in or out, right? If it is not screwed in tight enough to seal the valve body in, it can leak around that? You can also put in a new valve, if damaged
decent details here >
It’s leaking from the base underneath the nut, as if the vulcanization failed from where the outside of the metal part is vulcanized to the rubber part.
Personally, I think the inner tube was defective, but no way to prove it since they cut it in half to take it out before charging me to install another one. Tube is Gateway from Korea.
VANTAGE 38' FRAMELESS ALUM DUMP TRAILER (A64278)
VANTAGE 38'...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
