DEF Use & Problems ?
   / DEF Use & Problems ? #11
If you run a dpf tractor the way that is recommended by the dealer, it should be no problem.
   / DEF Use & Problems ? #12
I doubt that tractor has DEF. It probably uses a DPF. A DPF isn’t my favorite thing but it seems to be fairly reliable. A lot more so than DEF.
DEF = diesel exhaust fluid. DPF = diesel particle filter.
   / DEF Use & Problems ? #13
DEF = diesel exhaust fluid. DPF = diesel particle filter.[/
You are probably correct
   / DEF Use & Problems ? #14
:ROFLMAO: I’m running a Ram with DEF and from the reports, I’m lucky my DEF pump still works. They are a 1300 dollar unobtainiumm dealer part (800 aftermarket). So, that may be worth checking with the LS dealer
Probably very true. I know the def sensors are super hard to come by for our class 8 trucks right now.
2011 Ford Escape SUV (A55853)
2011 Ford Escape...
flooring (A55758)
flooring (A55758)
2005 Ford F-150 Crew Cab Pickup Truck (A55852)
2005 Ford F-150...
24" X 30' Corrugated Pipe (A56469)
24" X 30'...
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
Miller Stick & Mig 3 Phase Welder (A56469)
Miller Stick & Mig...
