DEF Use & Problems ?
   / DEF Use & Problems ? #11
If you run a dpf tractor the way that is recommended by the dealer, it should be no problem.
   / DEF Use & Problems ? #12
I doubt that tractor has DEF. It probably uses a DPF. A DPF isn’t my favorite thing but it seems to be fairly reliable. A lot more so than DEF.
DEF = diesel exhaust fluid. DPF = diesel particle filter.
   / DEF Use & Problems ? #13
DEF = diesel exhaust fluid. DPF = diesel particle filter.[/
You are probably correct
   / DEF Use & Problems ? #14
:ROFLMAO: I’m running a Ram with DEF and from the reports, I’m lucky my DEF pump still works. They are a 1300 dollar unobtainiumm dealer part (800 aftermarket). So, that may be worth checking with the LS dealer
Probably very true. I know the def sensors are super hard to come by for our class 8 trucks right now.
2014 Wacker BPU 3545A Reversible Vibratory Plate Compactor (A55787)
2014 Wacker BPU...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
Enmark Z Spray (A53316)
Enmark Z Spray...
2007 Kawasaki Mule (A53314)
2007 Kawasaki Mule...
