Deere advert
   / Deere advert #1
PILOON
Super Star Member
North of Mtl,Que,Can (Ste Adele)
MT180D
I only have dialup service and find that loading takes much longer with the Deere advert that uses flash player.
(The one wherby the tractor mounts a mower and then adds a loader).
I gather that a lot of rural users are faced with 'Dial up' only service.
Perhaps Deere could redesign out of consideration to us 'slower folks'.
Otherwise would like to add my praises for this site as it is part of 'my daily reading'.
   / Deere advert #2
Hi Bob,
Banner ads can be frustrating for those on dial-up access. When we lived in the country we had 26K dial-up for many years. It can be real slow.
Web sites and advertisers do design their offerings to accommodate the majority of users. Today, nearly 65% of Internet users in America have some form of broadband access.
If it is not available to you, I suggest you use one of the "ad blockers" that will prevent such ads from appearing at all. That is the only reasonable and immediate solution for you I can think of you.
Ad-Shield is only $20.
Search on Google for "free ad blocker" and you'll find many choices.
Just make sure that any ad blocker you want to use does not install any kind of it's own adware, which can be worse than the banner ds. /forums/images/graemlins/frown.gif
Hope this helps.
   / Deere advert #3
Money!! Bet that of your 65% hi speed less than half read TBN. I would say that more tractors are owned by dial ups than dish or cable people. bcs
   / Deere advert #4
We could take an un-scientific pole of who uses dial-up VS who uses anything else. Anything else would be something other than dial-up. Many folks check TBN at their place of employment, too, so they have access to both. So the survey would have to include dial-up, higher speed, or both.
I use both. The only difference I have noticed at home on dial up is that the first time a graphic loads, it is slow. However, once a graphic loads I believe it is held in my cache and doesn't download again. Not sure about flash presentations, but I think they are cached as well, just like jpegs, gifs, etc....
   / Deere advert #5
I have just bought a new computer a Pentium d
this has all the latest inside..............
I have satilite connection.................
THIS IS THE SLOWEST WEB SITE THAT I LOOK AT.............
I use to look at all of the chat lines but I Do not have the time to do it any more as THIS WEB SITE HAS SLOWED DOWN.
The numbers at the bottom of the page that it takes to load a page IS NOT the time it takes..................
Doug M
   / Deere advert #6
I visit many other websites and this one loads the same as any other at both my locations. The number at the bottom is not the speed that it is downloaded to your site. There could be many problems/bottlenecks between the place where the website is hosted and your end. I surf TBN at home on 28.8 and it only takes a few seconds for each page to come in. Very snappy for dial-up.
   / Deere advert
Maybe 65% have hi speed but in most rural areas it is not available.
Guess that they figure that rural folks (farmers) no longer use tractors and implements.
All I know is that my TBN time is limited so I now read much less trends as too much valuable time is used up waiting dor the green tractor to couple to the loader.
And the darn thing has to reload every time I click back to 'INDEX'.
Is Deere getting the kind of exposure they wished for?
Does TBN only want readers to look at Green tractors rather than browse trends?
FYI, I am logged at 46667 bps which is not bad for dialup.
I also have adaware and skybot installed as well as a 'speed-up pgm' from the server called V2 service.(this reduces the pic quality for faster loading)
   / Deere advert #8
If you use view last 1, 6, 12, 24 hours etc. you will find that TBN runs much faster.
   / Deere advert #9
Of course I'm now using the 750k DSL service and this page "Generated in 0.199 seconds in which 0.191 seconds were spent on a total of 6 queries. Zlib compression enabled." The last page generated in 0.065 seconds. It think TBN is as fast as any site for me.
   / Deere advert #10
Not to get in any spitting contests here or anything, TBN is slower when the Deere ad is up. Not slow as in extremely slow but it does add a second or two to the process, you can tell when you hit the refresh on the main index. Just wish that he could that loader mounted a little faster. My JD came with the loader on. /forums/images/graemlins/grin.gif
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
2022 CATERPILLAR 279D3 SKIDSTEER (A51246)
2022 CATERPILLAR...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
KMC 5610 (A53084)
KMC 5610 (A53084)
2003 Paris Utility Trailer (A52377)
2003 Paris Utility...
