Deere 4500 / 460 loader - Float
/ Deere 4500 / 460 loader - Float #1
jeffesonm
Hopewell, NJ
JD314/4310
I recently got a JD 4500 with the 460 loader. I pushed the joystick all the way forward and felt the notch which I assume is the float position... it is supposed to lock in the float position, correct? Mine doesn't seem to want to stay in the forward position. Any ideas?
/ Deere 4500 / 460 loader - Float #2
Yes, it should stay forwards in the float mode. Start with the linkages and make sure everything is well lubricated and free from excesses slop. I guess is that its not going completely into float and that's whey it popping out.
/ Deere 4500 / 460 loader - Float #3
If the above does not fix the problem, you may have to go into the cans on the bottom of the valve and inspect the spool for rust, crud, etc.
There are little springs and steel balls that fall into a groove to activate the detent.
When all cleaned up, lube well and put everything back together.
The drain hole in can should be at the bottom.
Thanks... I will check it out. Tractor has very low hours and was garage kept, so hopefully it shouldn't be too bad.
2015 PETERBILT 579 TRI/A DUMP TRUCK (A59914)
2015 PETERBILT 579...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2004 Chevrolet Silverado 1500 Pickup Truck (A64556)
2004 Chevrolet...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
