Deere 1050 seems weak
/ Deere 1050 seems weak #1
dmelvi41
Gardner, MA
John Deere 1050
Bought a 1987 Deere 1050 a couple days ago and feel as though the hydraulics are a bit weak. When trying to move snowbanks, the loader didn't have enough power to lift them. Has enough down pressure to lift the front wheels, but it also has a backhoe on the rear. Is there an adjustment to the bypass valve on the pump or in the banks? Hoping to find a quick fix that doesn't involve installing gauges or testing oil viscosity. It just had its service done at a dealership where they replaced the filters and fluids. I'll take any advice as I need it to do work for me!
/ Deere 1050 seems weak #2
If it has a sump pick up screen like our bigger JD they may not have cleaned it. What was the air temps?
/ Deere 1050 seems weak #3
Possibly has a weak pressure relief valve. I would suggest checking hyd pressure with a gauge. It appears it has a screen plus a filter.
Air temp today was about 40. Didn't change any as we used it. Backhoe squeals when rotating the boom to the left. How big a pain is it to pull the sump screen and filter? I'm mechanically inclined, but have never rebuilt a motor.
/ Deere 1050 seems weak #5
hyd filter is a spin off/on type and the screen appears to require removal of 3 studs.
Sounds good. I'll take a look tomorrow and see if the screen is clogged
(2) UNUSED 380/85R30 TIRES W/ 10 LUG RIMS (A64280)
(2) UNUSED...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2004 Dodge Ram...
2005 Rolls Rite 26ft. 24 Ton T/A Tag Tailer (A61573)
2005 Rolls Rite...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
1990 John Deere 755 (A64119)
1990 John Deere...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
