Deere 1050 seems weak
/ Deere 1050 seems weak #1
dmelvi41
Gardner, MA
John Deere 1050
Bought a 1987 Deere 1050 a couple days ago and feel as though the hydraulics are a bit weak. When trying to move snowbanks, the loader didn't have enough power to lift them. Has enough down pressure to lift the front wheels, but it also has a backhoe on the rear. Is there an adjustment to the bypass valve on the pump or in the banks? Hoping to find a quick fix that doesn't involve installing gauges or testing oil viscosity. It just had its service done at a dealership where they replaced the filters and fluids. I'll take any advice as I need it to do work for me!
/ Deere 1050 seems weak #2
If it has a sump pick up screen like our bigger JD they may not have cleaned it. What was the air temps?
/ Deere 1050 seems weak #3
Possibly has a weak pressure relief valve. I would suggest checking hyd pressure with a gauge. It appears it has a screen plus a filter.
Air temp today was about 40. Didn't change any as we used it. Backhoe squeals when rotating the boom to the left. How big a pain is it to pull the sump screen and filter? I'm mechanically inclined, but have never rebuilt a motor.
/ Deere 1050 seems weak #5
hyd filter is a spin off/on type and the screen appears to require removal of 3 studs.
Sounds good. I'll take a look tomorrow and see if the screen is clogged
2014 Bobcat E63 (A64126)
2014 Bobcat E63...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
ATTENTION! PLEASE READ (A64127)
ATTENTION! PLEASE...
2011 BRENNER TANK TRAILER (A65643)
2011 BRENNER TANK...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
