Deep Snow
/ Deep Snow #1
northern21
Kasson, MN
bobcat 763, Farmall Super M-TA
Hi everybody. I was wondering if any of you have done any mulching in the snow? I will be running a RC-100 with a Fecon head. Snow is pretty deep around here in Minnesota but I would like to complete a large job before the Spring thaw. Any tips or advice is appreciated.
/ Deep Snow #2
Well, probably not deep by Northern standards, but I have mulched in 8" of snow in NC. Didn't cause any problems other than hiding the terrain so be careful.
If it's really deep, you may not be able to get all the way to the ground.
/ Deep Snow #3
Don't work in an area with rocks. They pretty much stop here in the winter I assume due to costs from all the rocks.
/ Deep Snow
Not worried about rocks. the site is a wetland overgrown with willows and brush. Terrain is flat. I don't need to get it all the way to the ground. I will be following up with spraying and burning in subsequent years.
/ Deep Snow #5
I've worked in 18-20 inches of snow with the skid steer. Hills are tough and progress is slow going. the head will bog down when you stick it in the snow, slow enough that the sumps will be taller then the top of the snow...of course bigger material would be easier to get a good stump. The place looked aweful in the spring but we got the job done and we didn't have any stump height requirements on that job. I would say plan oin 60-70% of normal production on a good day.
The excavator did better in deep snow on another job but we still needed to come back in the spring to lower some stumps.
/ Deep Snow #6
It's a great time to get those swampy areas when frozen. I'm bustin my butt right now in areas normally too wet to walk in, let alone get mulcher in there. There are advantages; machine runs cool, no dust, and snow lubricates the mulcher drum & nothing jams. I'm thinking of adding a windshield wiper to the forestry door. Snow sticks and obscures my vision. Fortunately I don't have a rocky area to avoid. In some areas, I've been working in 20" of snow without problem. Hydraulic & diesel leaks are easier to detect in the snow and I'm not complaining about the ASV AC system.
/ Deep Snow #7
As everybody else has said its going to be slow going, and beware of rocks but it seems that you wont have that problem. if your not worried about the height left when finished and you can get through the snow then i say go for it.
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A64194)
Pemberton Inc...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2006 Volvo VNM T/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM T/A...
2025 Kubota L4060D 42HP 4WD Utility Loader Tractor (A64553)
2025 Kubota L4060D...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
