Deck Stairs Rotten
/ Deck Stairs Rotten #21
No 2X material is now rated for "ground contact", you need to go up to a "timber" size material, possibly 4x4 & up but I'm pretty sure that a 6x6 is rated for ground contact but that does not help you with your stair stringer
That's actually the fault of your lumber store or their vendor, not the mills. Ground contact 2X is still commonly manufactured. Often you have to buy it from a commercial lumber store, not Ace or a big box.
http://www.menards.com/main/deckest...ated-pine-lumber-ground-contact/p-1414288.htm
/ Deck Stairs Rotten #22
Looks like replacement is in the works. Pt wood, coat it again with several coats of rot restricting product, use sill plate gasket material between risers and the foot boards, a couple of times a year wash everything down with a mixture of dish soap & chlorine bleach (mixture is about that much of each) to maybe thwart new growth. I do this with the pressure washer and the eductor feature.
The failure may have been due to lumber quality?? but that is in the past.
/ Deck Stairs Rotten #23
Some good advice here - but what ever happened to the treated lumber that was supposed to last a hundred years? Not that it ever did but it was better than it is now,,,.
/ Deck Stairs Rotten #24
There's no environmentally friendly way to prevent living organisms from feeding on cellulose--its what they've evolved to do. I understand we want toxins out of food, water, and living space, but the only wood that doesn't get eaten, is toxic wood.
/ Deck Stairs Rotten #25
Copper is quite good at that, the issue becomes the other metals needed to alloy with copper to allow treatment and the use of modest amounts of expensive copper.
/ Deck Stairs Rotten #26
I've seen similar issues on stair stringers but more often than not the ones I see are usually caused when 2x treads are nailed down with large non galvanized or cheapo galvanized nails...even with PT water can seep down the shank of the nails eventually rusting the nail to the point that it splits the wood that has been taxed by all the moisture...
I've got some close to 40yo PT 2x6 decking that is still in decent shape for it's age...but a lot of places where water has laid in the nail divots the PT has rotted a bit...
/ Deck Stairs Rotten #27
I'd do back flips to be able to get 40 yrs. out of PT lumber, today's (PT) is more like 4-6 years.
/ Deck Stairs Rotten #28
I can get ground contact (2X material) from my commercial yard, but It's special order and I need to take a whole lift minimum order. There's just not enough builders that need PT for anything more than the "green plate" where framing contact's masonry/cement and today's junk PT does that fine so it's not a high demand item for GR lumber.:mad:
Here's an update. /Pine is close to the reason for my problem. I have removed the rotten stringer and the Hardi-Plank risers. When I got the risers off I could see that frontmost screw that holds the tread onto the stringer was too far forward and split the riser face of the stringer on almost every step. I'm pretty sure this is the cause of the rot since where this happened on the remaining 3 stringers the same thing is starting to happen but not as bad. I think the screws were too big, they used four per tread and, again, the forward most screws were too far forward and split the stringer.
I had to remove all the Hardi-Plank risers. There is just no way to get them off without breaking them. I may or may not replace them. Will replace rotted stringer tomorrow. Interestingly the bottom of the stringers sit on a little concrete pad but it is now below ground level and for all intents and purposes they are sitting in dirt but that part of the stringers is still quite sound. I think the whole stairway will need replacing in three or four years but I'm not up for it right now. I'll paint the new one and the exposed areas of the old ones and it will be fine for a while.
And speaking of PT lumber, I was cleaning out my tractor shed down at my cabin and found some of that green, wet, heavy 2x8 piece PT lumber like you could used to buy lying in the woods on the ground. I picked it up and the ground side was a little discolored and spongy down to about 1/8 of an inch but the rest of it was fine and structurally is was sound. It had been there for 10 years. This new stuff is not up to that.
/ Deck Stairs Rotten #30
The only thing I can see that might be a clue is that the carpenter that cut the stringer made the cuts where the riser and the tread meet with a circular saw (which is normal) but rather than finishing the cut with a hand saw he extended the cut into the stringer in both directions with the circular saw. To me, that's just lazy and sloppy but I'm not sure if that is why this stringer rotted so fast. Maybe this extended cut was a site for water to get into the wood? Any thoughts on this?
When is the last time you used a hand saw?
I use a chisel, or sawzall, if I care. That is not why it rotted though.
Treated wood changed 10 years ago. Which is why you have to use stainless or treated fasteners. I don't know how many people actually do it, but you should paint or stain cut ends. I am not sure if it has always been that way, but the treatment is on the surface.
Boards on a wall are vertical, as opposed to stairs, this is probably a big factor.
Do you salt your steps in the winter? If so that may be it.
I just painted some steps, with a product I was told was great. I didn't prep the wood, so it may be my fault. But it is already coming off in a couple areas. Dog's nail probably the reason. Wish I would have saved the $50 and go some new boards and stained them, next year. You need to wait before painting or staining.
/ Deck Stairs Rotten #31
I used the same trick but instead of using galvanized tin I used felt paper. In the many pole barns I built, I learned early on that the roof would sweat with water running down on my 2x8 rafters causing them to rot.
er.
Contractor who just built mine put plastic between metal and trusses, for this reason. He told me to use pressure treated wood at the floor, becaus concrete sweats. I read about poles rotting out.
The other pole barn built around 1985 has foam board, which may be the reason. Though you can see some of the trusses have water stains. Dirt floor and poles look fine.
/ Deck Stairs Rotten #32
It's the crappy treating process/chemicals. For some reason the good CCA chemicals of old were outlawed, EPA? No 2X material is now rated for "ground contact", you need to go up to a "timber" size material, possibly 4x4 & up but I'm pretty sure that a 6x6 is rated for ground contact but that does not help you with your stair stringer. I have a 4 year old picnic table & the PT "leg" is rotted where it touches the ground:confused2: I guess that the EPA wants us to go back to dipping/painting our lumber in crankcase & diesel oil every few years.
4x4 are rated for ground contact, most likely because they are used for decks. But ya, I wish they stock 2x6s for ground contact.
Though if you paint the wood, it will last a long time. Look at homes.
I use a handsaw all the time. There are plenty of jobs for which a handsaw is the right tool, the finish cut on stair stringers being one of them. But I agree, that was not the cause of the rot. The cause of the rot was improper screw placement splitting the stringer.
/ Deck Stairs Rotten #34
Maybe, but I am not 100% convinced on that. Maybe the paint or stain didn't get in the crack, that is possible. The idea the crack created a pocket for water, I dunno. Stairs have many horizontal surfaces. But I have not seen it myself, I am just a skeptical person.
I've done a lot of building the last few years, so have to see how my stuff goess. I question the new pressure treated wood. If it was better, the government would not have needed to force it on us.
You are done south, so I am guessing salt wasn't it. Up north that would have been a top guess.
/ Deck Stairs Rotten #35
In 1990 I did a board fence with 4x4 green treated posts from Home Club... the posts are perfect.
In 2005 I added a section and used brown treated posts... they are starting to go.
/ Deck Stairs Rotten #36
Well we get 100 year floods and storms every 4 or 5 years nowadays so the lumber manufacturers figured they would shorten up the 100 year wood life too. :D
Paint did not help, it traps moisture. Not treating the cut was a green light to the problem.
/ Deck Stairs Rotten #37
Before Pressure Treated I only used Heart Redwood and it worked OK.
I recently replaced a few treads for a neighbor and he bought heart redwood... never did find out what it cost... he just said EXPENSIVE
A friend I grew up with lives off grid in a redwood forest and just built a small shop 20x20... he felled a Redwood Tree, tossed any "White" wood and milled the rest for his shop... his father in law has a porta mill.
When I say the quality of the lumber I said a guy could go broke fast... he said it was FREE outside his labor.
There is a pretty good correlation between the areas that are starting to rot on the remaining stringers and where the screws split the wood. In places where the wood is not split there is little or no decay. The quality of the lumber is likely the prime culprit but I believe the split areas are the catalyst. If not then it will remain a mystery. And, there is no paint or stain on the stringers other than on the outside edge of the one that rotted out. The paint was purely for looks.
No salt but high daily humidity and this back part of the house does not get much sun.
For me, the take home story is that the current average big box store treated lumber is not going to last like that wet, heavy green stuff used to and that if you don't do everything just right with it you're going to get 4-5 years out of it. This will definitely affect future projects in my mind. Unfortunately I just completed a small deck (8'x 18') on the back of my cabin using this yellow stuff. We did stain it.
My father-in-law built the extensive decking around his house out of redwood nearly 40 years ago. About 5 years ago it was starting to rot in places and was looking bad. He removed it all but was able to plane down about 75% of it and reuse it. It looks good again now and I'd guess he'll get another 10 years out of it. So 50 years is not too bad.
Red cedar is the thing around here but it has to be old with plenty of red heart wood. I have an old barn on my property. I'd say it is at least 75 years old. It is slowly falling in but the main support posts are red cedar stuck right in the ground and they are still solid. You can see where they trimmed the white outside wood away at the bottoms so nothing but the red heart wood goes into the ground. The local farmers do this for their fence posts too. Unfortunately it is getting hard to find cedars old enough to have enough heartwood for this type of duty.
/ Deck Stairs Rotten #40
Without seeing it myself, I find it hard to believe that the opening created by the wood cracking would have anything to do with it rotting. The pressure treating process easily gets all the way through a 2x piece of lumber. Rot is caused by mold growing on the wood. The mold needs moisture, heat and food to survive. The treatment process is supposed to remove it as a food source, but like you said, it isn't like it used to be. If there is enough moisture there long enough, it breaks down the chemicals in the wood and it becomes food for mold. The problem is you have too much moisture there. If it was properly ventilated, the additional surface area created by the crack in the wood shouldn't matter one way or another. I've seen way too many cracked boards without any rot to believe this. I've also see a lot of rot on nearly new decks that didn't have any ventilation. Air flow is the key to keeping lumber dry, and how long it lasts.
H&H 100 GALLON ALLY WAY SPRAYER (A63291)
H&H 100 GALLON...
1985 MRK BOAT 2011 HMDE TRAILER (A61574)
1985 MRK BOAT 2011...
2015 HYUNDAI HX220L EXCAVATOR (A64279)
2015 HYUNDAI...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
2014 Komatsu HM400-3 Offroad (A62679)
2014 Komatsu...
